CFD - 2022 F1 Car
humble sabot
27
Re: CFD of 2021 F1 Car
godlameroso wrote:
22 Dec 2019, 16:04
CAEdevice wrote:
21 Dec 2019, 23:39
I am simulating a car (not a F1, it is nearer to a F3) with a F1 2021 floor layout: I am pretty sure (as you wrote on the article) that the optimum rake will be around 0°, no matter if the front wing will be (a bit) more distant from the ground. You will have a significant drag reduction and you don't have a diffuser peak to balance.
Perhaps a little bit of rake will be needed just for balance, the shift in rake at speed may also have very interesting effects on that balance. Particularly roll, and pitch.
What if more, not less body roll and pitch is favorable to the 2021 generation of aero rules. It would certainly force drivers to adapt a new style of driving, pitching and rolling the cars to set up for corners.
Very light brake application on corner entry to get the front end to turn in, and having to semi inertial drift the turns to get the most of the aero platform.
If you're suggesting that the floor is so easily stallable, I'd suggest that they would be more likely to err on the side of a firmer platform.
Current gen cars actually have a fair bit of compliance through corners compared to most other race cars, particularly at the rear, and it's the floor heigh that allows that to work as well as it does.
That being said I would subsequently expect that exploiting this floor format to its maximum will see some new kinds of out of the box thinking as most high budget series have not been playing around with full floor tunnels.
the four immutable forces:
static balance
dynamic balance
static imbalance
dynamic imbalance
humble sabot wrote:
07 Jan 2020, 23:57
godlameroso wrote:
22 Dec 2019, 16:04
CAEdevice wrote:
21 Dec 2019, 23:39
The stalling is mostly from the way the front of the car deals with airflow, however diffuser performance will increase the closer it is to the ground up to a point.
maunde
Vyssion wrote:
17 Dec 2019, 14:38
G'day! It's been a while... hasn't it? :)
With the 2019 season now concluded, and jjn and I being in stage 4 withdrawals right now, we figured that we needed "something" to keep our mi... ooooooo!! Is that the 2021 regulations??? :lol:
So, without further ado, I would like to present to you all our first, and legal (to the best of our knowledge), 2021 spec. F1 car!! And the first car that is wholly of F1T design!!
-sigh-... who would have thought that Aerosaruman and Aerogandalf would ever work together again, huh? =D>
https://imgur.com/PYnaTVH.png
https://imgur.com/guOyb4N.png
https://imgur.com/IeQhAHn.png
So.......
What forum post from Vyssion would be complete, without some CFD: COLOUR FOR DIRECTORS!!
Very similar setup to the Perrinn model; straight ahead solve here, no crossflow or curved flow, steady-RANS w/ SST turbulence inc. wall functions, 31.5million elements, etc etc...
https://imgur.com/P6ED0ny.png
https://imgur.com/5R58Ahv.png
https://imgur.com/ThzSwAg.png
Here is a list of bullet points that, so far, we have twigged, and are gonna work on next. Now I am gonna shamelessly make excuses for any "iffy" performance or flow features you see, because... IT WAS OUR FIRST GO AT IT, OKAYYYY?? :cry: Overall, for a first go at it, the car performs very, very well; hats off to jjn.
  • CzS = -4.95
  • CxS = 1.80
  • Front Wheel wake is pretty crazy now... we will work on this
  • Going to reduce pitch setting of FW flaps
  • Inboard floor fence vortex isnt under control (just spreads out)
  • 2021 Force Breakdown = Floor (50%), FW (37%), RW (25%)
  • Compared to Perrinn = Floor (55%), FW (30%), RW (40%)
  • Higher than 100% is due to Lift generated on the chassis and wheels (6% lift on 2021 wheels, 9% lift on Perrinn)
  • Balance of 2021 is ~49% which is quite far forward, so we will correct this (starting with FW flaps as mentioned above)
  • Surprisingly large amount of low pressure below the car
  • Front suspension is stalled
  • Top of floor inlet is stalled
  • Rear of Lower sidepod expansion has stalled
  • RW flap stalled in curved EP sections (and slightly along TE) and RW as a whole is very draggy
-edit- replaced old gifs with larger ones - I made a mistake when I was creating them... oopsies
https://imgur.com/s0WIUwj.gif
https://imgur.com/rUTxoyq.gif
https://imgur.com/KYFQvuG.gif
https://imgur.com/2faOvGm.png
https://imgur.com/1wXjL5V.png
https://imgur.com/zTHRlNz.png
https://imgur.com/zueL8hT.png
https://imgur.com/bBaIjl3.png
https://imgur.com/9fPR6mf.png
https://imgur.com/kLcnClK.png
Hey Vyssion,
Would you be able to talk more about the rear-wheel fence/strake-like/vane features adjacent to the rear wheels? What are your thoughts on the expected interactions between these vanes and the diffuser? My assumption is that this could be used to control the rear-wheel tyre squirt as well as aid the diffuser (preventing in-flow).
Did you notice any interesting flow regimes in this area?
Thanks for the feedback!
A kiwi looking to fly like McLaren.
jjn9128
771
Those fences/vanes are spec parts. Though there is leeway for a small angle so the teams can play with it to adjust to their individual flow fields.
As they're not fully detailed in the regs I had to make them up from the little information available and the pics of the wind tunnel model. I feel we've recreated the purpose if not the exact geometry. Same goes with the front arch winglets!
The purpose is to stop the tyre squirt entering the diffuser. The bigger Venturi/diffusers draw a huge volume of air from the sides into the end-fence vortical structures, so stopping "low energy" stuff like the tyre wake getting in is important.
They do the job pretty well if you look at the gif. The tyre squirt doesn't mix with the diffuser flow until behind the car. So is not directly affecting the downforce generating surface.
#aerogandalf
maunde
jjn9128 wrote:
10 Jan 2020, 14:08
Thanks for the reply.
That's quite disappointing they are spec parts - it would have been an interesting part to optimize. Ofcourse this area of freedom doesn't necessarily help the intention of the new regs.
How would you differentiate between the characteristics of the tyre squirt vortex and the vortex generated by a vortex generator used for downforce generation (the front underbody vanes, for example)? Can the tyre squirt vortices be used for downforce generation?
Cheers
jjn9128
771
How interesting it would be to develop would depend on how tight of free the rules are. Sadly I don't see a huge amount of interest in developing parts for the 2021 rules as they're incredibly prescribed.
The function of vortex generators must be seen in relation to scale. So a small vortex generator on a wing or diffuser surface will influence the surface at boundary layer scale i.e they're boundary layer turbulators. The point being to shift the stall condition. So more camber/incidence/lower ground clearance increasing pressure gradient.
Larger vortices have larger effects so aren't useful for that boundary later scale. Mostly they're from geometries aimed at turning the flow but the core can infer a pressure on a surface. Under ground effect the vortex core generally remains fixed as it progresses in a stream wise direction.
Tyre squirt is tricky to control. The size of the vortex isn't static. Changes to the sidewall compression or camber (mid corner a negative static camber can become positive depending on roll stiffness) can have large effects on the size and position of the vortex. This is part of the reason for 18" wheels. Certainly why I suggested it to FOM. Though I think they've somewhat counteracted that by increasing the diameter to 725mm.
#aerogandalf
maunde
jjn9128 wrote:
10 Jan 2020, 14:48
You are insightful as always!
This all makes sense. How often are larger scale generators used solely for vortex generated downforce? Without much regard for actually turning the flow? I am aware that this would depend on the availability of ground affect, but would like to know your thoughts on the topic.
Cheers
jjn9128
771
Generating the vortex requires some form of cambered surface and the downforce you get from the core isn't that big compared to the drag you produce to create it anyway, probably closer to 1:1 than say a T wing which will be of the order of 10-15:1. As a side effect or secondary effect it can be beneficial as a main aim it's generally not worthwhile. I say generally because there are exceptions where the downforce is essential regardless of how dirty or cases where the drag will offset elsewhere.
An example would be the vanes in modern diffusers. They're not fences of multi channel in the tradition sense.
#aerogandalf
JordanMugen
82
maunde wrote:
10 Jan 2020, 14:31
Cheers
Isn't that what the Valkyrie diffuser design is for? To bring in the tyre squirt to contribute to the diffuser counter rotating vortex pair.
What I have noticed is that the rear end of the car will be the biggest area teams can improve on. Meaning the best and tightest packaging of the chassis will have the best aero performance. This is still something that favors the big teams, if you look at the packaging of the rear end of the Mercedes vs an Alfa Romeo you can see just how much more sculpted and aggressive the Mercedes design is.
That level takes a lot of engineering and development to improve. It is a very costly area to develop as the parts must be over engineered to last. These parts include the transmission, the radiator layout, the fuel tank, survival cell. All of these things affect the engine installation which affects the balance of the chassis as well as aero performance.
Airshifter
That's a lot of work to create those visuals. Well done guys!
Though I only dabble in the understandings of the aero impact, with the huge budgets of the teams and their vast resources I'm sure they will figure out the balance and setup issues with all the lead time they have.
The wakes of the current spec cars have just been out of control for so long that the new regs should really tighten things up and make the close following on attack possible again. If this all works in the end we might actually see elimination or reduced impact of the DRS. Though it was one of the only "quick fixes" it's been just that if you ask me, and at times has been too much of an impact on overall car setup.
jjn9128
771
Airshifter wrote:
02 Feb 2020, 16:13
Thanks.
I think we should expect a bigger gap between teams, as always happens with a big rule change, so wheel-to-wheel might not be any better at all. Especially if one team gets the jump on the others (likely Red Bull or Mercedes) and is always 30s up the road!!
I think they could/should have been more ambitious with this rule change - the big issue for the wake is drag so they should have tried to force a massive drag reduction. That then feeds into the environmental image and OEM targets where they can use less fuel for the same speeds.
#aerogandalf
izzy
izzy
jjn9128 wrote:
02 Feb 2020, 17:14
my basic understanding is they've specified the aero so tightly that it'll be quite hard for the cars to be very different! That was part of their plan. Then the next thing was that the floor tunnels won't be so affected by being in a wake, and if that's true then after that we actually want drag as that is also the tow.
environmentally tho, yes big issue, they should've halved the ICE to 3 cylinders and let them loose on the battery if you ask me, once they have a budget cap. They'd have to do something as with 1000 hp and low drag it would be a bit crazy
jjn9128
771
izzy wrote:
02 Feb 2020, 20:29
That underbody tunnels are less affected by wakes than flat floors with a diffuser is one of those truisms which isn't necessarily true. Certainly I think the balance of the cars should be less affected, but the main improvement with regards to the downforce loss in the wake is the big rear wing pulling the wake upwards. That in turn means there's less wake at ground level to go into the floor tunnels.
I agree that lower drag cars would probably require less power to prevent top speeds being too outrageous, but then you'd want less mass so you could accelerate the cars out of corners. I like the Ben Bowlby LeMans Deltawing approach of 1/2 mass, 1/2 power, 1/2 drag, 1/2 fuel. I think the plan for 2024 sounds like 3 cylinder opposed cylinder engines at which point I think they should also be aiming for a significantly lower fuel allowance (at least down to 75kg) to really highlight/drive economy while obviously maintaining good racing. Current
I also like the Frank Dernie idea of super hard tyres which last a full race plus the practice sessions for the next event (obviously manufacturing and transporting fewer tyres to each track) - it's often overlooked in the aero issue of overtaking that a single rubbered in line plus the detritus off-line makes racing even more difficult. If the cars are grip limited too then drivers can make mistakes which can lead to further opportunities.
#aerogandalf
izzy
izzy
jjn9128 wrote:
02 Feb 2020, 21:32
izzy wrote:
02 Feb 2020, 20:29
Oh, well i hope Nikolas & co have got it right with the tunnels, and also actually cut the outwash this time. Yes the cars are too heavy aren't they, anyway, they ought to abandon all those minimum weights, raise the crash test levels a LOT and let teams fight it out on weight, including the battery. Liberty seem to want to force close racing in F1 like F2, forgetting that hardly anybody cares about F2 BECAUSE the cars are all the same!!
Tyres, well F1 is the biggest example ever of unintended consequences isn't it. If they went to no pitstops i think they'd have to go to Ross's reverse championship grids, otherwise too often the fastest car would start in front and just go round and round there
