Red Bull connect shark fin to rear wing
As the teams are coming out with their final Melbourne aerodynamic packages, Red Bull once again drew all the spots to itself with a new type of shark fin never seen before. While all previous versions could be considered an extension of the engine cover, the new one actually connects to the rear wing. The element stretches up to the maximum height of the car, connecting the top of the airbox with the midpoint of the upper rear wing element. As such, the rear wing is effectively split in two halves and therefore even more efficient under yaw. The initial aim is only improved, and it's probably just a matter of time before others will show up with similar designs.
Tho you could expect it it is still interesting. By this the negative effects of the fin are removed/reduced, so i will see alot of other teams using this.
