godlameroso wrote:Is KERS going to last longer than 6 seconds next year? What about for 2013? It would be a nice idea to instead of making KERS a push to pass, it would work seamlessly with the engine. That way you could eliminate turbo lag, just compliment the engine with the electric motor to improve low-end torque, without affecting top end speed. You could have the torque of a diesel, with the revs of a petrol. On the other hand, you could also use the KERS to boost high RPM torque; and I'm pretty sure you could change all of this as easy as you can change an engine map.
You could even go as far as having a hybrid economy mode. I think it's entirely possible, seeing as how the electric motor is connected to the drivetrain, to use the electric motor so as to remove any strain the engine has. Meaning that the electric motor only works to offset the pumping losses of the engine, thereby, hopefully improving it's efficiency.
There is NO turbo lag on modern engines. And if the exhaust blown diffuser is continued, the engine revs will be kept up electronically, there would be absolutely no way that full boost would not always be instantly available.
