Are there any concerns that the nose is too deep now? I mean, maybe some car gets under the barrier.
Agree that all stars have to be aligned for that to happen, but who had thought a spring will hit Massa...
The Problem basically is that the 2014 regulatiosn still allow for sufficient DF at the front of the car. With elimination of Beam Wing + EBD the trouble area will definitely be the rear end of the car.godlameroso wrote:I wonder if the noses have to look like that because the new philosophy involves guiding air through the chassis.
A fair point and the oft mentioned MP4-22 in this thread was a car involved in an accident that fits your concerns completely if we recall Heikki Kovalainen's accident in Spain in 2008.McMrocks wrote:Are there any concerns that the nose is too deep now? I mean, maybe some car gets under the barrier.
Interesting. Does the funnyshape nose in this thread comply to it?hecti wrote:The real limiting factor is the 9000mm^2 cross section 50mm behind the tip of the nose
That's only 95x95mm, not very bulky. I think it could.timbo wrote:Interesting. Does the funnyshape nose in this thread comply to it?hecti wrote:The real limiting factor is the 9000mm^2 cross section 50mm behind the tip of the nose
108 mm diameter on a circle. Don't know what the diameter is on that strap-on nose.CBeck113 wrote:That's only 95x95mm, not very bulky. I think it could.timbo wrote:Interesting. Does the funnyshape nose in this thread comply to it?hecti wrote:The real limiting factor is the 9000mm^2 cross section 50mm behind the tip of the nose
As long as that 95x95mm area is located between 135mm and 250mm above the referance plane and its center is no higher than 185mm it should be legal. Also remeber that in the nose there is a minimum radius of 10mm I believe(?? dont have the regs in front of me)CBeck113 wrote:That's only 95x95mm, not very bulky. I think it could.timbo wrote:Interesting. Does the funnyshape nose in this thread comply to it?hecti wrote:The real limiting factor is the 9000mm^2 cross section 50mm behind the tip of the nose
Well, it would be upvoting if below zero or downvoting if above zero.hollus wrote:Frukost:
Voting back to 0 is not exactly the same as downvoting. I think the difference should be easy to understand? I also keep on wondering what makes upvotes sacred and downvotes evil, that breaks the symmetry of the universe. And I am way off topic here.
Or 115mm high and 78,26mm wide.CBeck113 wrote: That's only 95x95mm, not very bulky. I think it could.
Remember that they do have to pass crash testing. If you make a skinny, low nose, then add the moment created by the force of a crash, you are going to have to have a very rigid nose, not ideal for disbursing energy and passing the crash test.henra wrote:Or 115mm high and 78,26mm wide.CBeck113 wrote: That's only 95x95mm, not very bulky. I think it could.
That leaves still plenty of room for ugly noses...![]()
In aircraft aerodynamics there is an old saying: If it Looks good, it will fly good.
Unfortunately that saying can easily be countered by tight ill-conceived Regulation which completely ignores aesthetic aspects or underestimates the creativtiy of designers.
