F1Technical Fantasy League 2013
Steven
Owner
This is the official discussion thread for the f1technical fantasy league.
We have an "official" f1technical subleague set up at http://fantasyf1league.com/ which you can join to compete against your friends on this forum. To join, you first have to login, then setup your team.
You will subsequently have the option to search for subleagues and join any number of leagues you want.
Our league is named "F1technical" and the password to join is "f1t2013"
Please add your nickname somewhere in the team's name your are submitting to make it a little bit easier for everyone!
megz
Re: F1Technical Fantasy League 2013
Quick note Tomba - the subleague isn't password protected at the moment.
That is true, I joined the subleague and it didn't request for any password.
LE: I did more math today than in the last 2 years. / My team is RO F1 Team
Steven
Owner
Protection fixed now, I think.
Also, seeing that nicknames aren't used a lot for team submissions, please post your team name here when joining. We can then compose a table of nickname vs team name.
lukeaar
lukeaar
Le Montreux
Sawtooth-spike
After a useless year in 2012, The Saw squad return for the 2013 F1T Fantasy Season. The team principle said he was sad to see HRT going, as he used them to make the numbers in his dream team.
I assume we will use the forum and not the comments section not the site?
I believe in the chain of command, Its the chain I use to beat you till you do what i want!!!
db__
db__
Oakaakboane
Bomber_Pilot
I'm new to F1 league and I have a question. You buy 4 drivers. What I would like to know is, are all four included in your score after each race or do you only choose two of them for each race?
aleks_ader
90
Aleksandergreat
elclingo
elclingo
Joined.
My team name: elclingo
enz0
enz0
Just joined
Username: TRBP F1
KWashburn
KWashburn
Washburn GP Engineering
Side Note - The options available are way different that gpupdatemanager.net
Miguel
Miguel
I've joined as well. I've probably have spread my bet too much. I'm "Kompilator Racing"
I am not amazed by F1 cars in Monaco. I want to see them driving in the A8 highway: Variable radius corners, negative banking, and extreme narrowings that Tilke has never dreamed off. Oh, yes, and "beautiful" weather tops it all.
"Prediction is very difficult, especially about the future." Niels Bohr
hollus
Not sure I understand how the constructor and engine points are allocated after the weekend. Will you get the points for the best finisher in the real team, for both, or for some sort of aggreagate? And also, with 11 "engines", the engine list looks almost the same as the constructor list, including the prices. The engines are marginally cheaper and provide some points less. Are they basically two choices in similar scenarios, so one can spread the odds if desired, or am I missing something here?
TANSTAAFL
RicME85
52
Im pretty sure I played this game last year but it has changed since.
Was just 2 drivers and non of this talent malarky either. Even better was the engines werent split into individual teams so you earnt points from any team that ran that companies engine.
Team name - Hit Reset Racing
