This is a new thread prompted by discussions that some drivers seem to use consistently less fuel than their team mates.
Firstly, has anyone got the data so we can have a quantified discussion?
Secondly what hypothetical driving style would aid optimising the fuel v lap time? For instance Hamilton seems to consistently use less fuel than Rosberg. That's even after fighting through the field at Monza or Spa when you'd expect aggressive driving to use more fuel than Rosberg running on an empty track.
I also expected Hamilton to suffer the most with fuel limits due his aggressive style. Maybe his famous late braking means he has longer in lift and coast. If two drivers lift at the same time then the late braker will have longer at higher speed. That means the late braker can lift a bit earlier without loosing lap time to the other driver?
Also Hamilton has a reputation for turning the car more aggressively. I recall seeing him in his debut season late braking into a hairpin, assuming he'd run wide on exit and begin surprised to see him get on the power earlier than the car he was passing (ie the one taking a conventional line).
Anyway that's just my random hypothesis trying to figure out how a so called 'aggressive' driver has lower fuel use than his teammate. Also, if I had that advantage I'd burn a bit more fuel to be a bit faster so why doesn't he?
What we really need is some teammate comparisons to see if other teams have similar marked differences.
