I do not know if this is helpful, which I took from
here, because I do not understand well what you mean by "impact range":
"The HANS device (which NASCAR made compusory six months after Earnhardt's death) saved Ritchie Hearn's life. "I went head-on into the wall at
210 miles an hour (139 G's). I didn't have a headache, I didn't black out - nothing. I didn't have a mark on me except for my foot."
[Sources: "Ultimate Racing Crashes" (Discovery Channel)]
This quote makes easier for you to imagine that the forces that the pilot suffer depend on retaining gear, chassis and speed as much as the barrier itself. It also gives you an estimate of the G forces invoved. Besides, a tire barrier is designed to disperse and decelerate, not to contain, as opposed to a concrete barrier.
A rule of thumb:
G force average = Speed differential squared/(2 x distance for stop)
For example, if you take the data from Mr Hearn's crash, that is 210 miles/hr, which is 94 meters/second, this means that the "squashing distance" was 6.5 meters.
By squashing distance I mean the crushed part of the car plus the movement of the barrier plus any movement allowed and restrained afterwards by the seat belts and the HANS (for your basilar skull fractures, which is your probable cause of death in a barrier crash at 200 mph). It is the total distance over which you were deccelerated. This distance is found in the previous equation as:
139 G = 139 * 9.8 m/s2 = (94 m/s2)^2 /(2 * 6.5 m) = V^2/2S
There are other factors: for example, if you use an airbag you distribute this force over a larger area of your body. Besides, the main force is applied on the last part of the decceleration (the last foot or so), so it is very important what part of your car stops you in this last foot: it is not the same to hit a solid steel Ford Fairlane's 1955 dashboard that a well padded Volvo dashboard in this last foot. The average G force from this simple equation is only a lower limit of what really hits you.
I worked for a while at
Turner-Fairbank. They have the
FOIL lab on barriers, but I think they have not tested a tire barrier, only standard road barriers. You can ask to
martin.hargrave@fhwa.dot.gov and he may answer you.
BTW, this lab always was a source of fascination to me as I saw them destroy over 100 cars in one year. They piled them in a huge parking lot I passed by every day. I never speeded with the same emotion afterwards. Who knows, maybe they will try one for you. Only in America...
