Mclaren Mercedes MP4-25
BreezyRacer
BreezyRacer
Re: Vodafone Mclaren Mercedes MP4/25
siskue2005 wrote:Image
Looks like the diffusor is starting from the middle of the sidepods?
am i right guys?
edit: is it legal anyone?
how can they start from the sidepod itself?
It's the upper section of the double decker diffuser that you see. You might as well think of it as a tunnel with a floor on it. They ended up getting close to this last year but it was more space limited because of interference with engines, trannys, suspension, etc.
Personally I have a hard time figuring out how all these teams are going to be happy about giving up all this downforce for next year, when DD diffusers are banned.
siskue2005
70
yup exactly what i meant
what happened to the rule of not having any diffusor infront of the rear axle?
or was i wrong in thinking like that??
BreezyRacer
BreezyRacer
siskue2005 wrote:yup exactly what i meant
That was never a limitation for the DD diffuser loophole. I don't believe there's any fore/aft limitation on the port holes that feed the upper diffuser. I'm sure it was interesting to figure out optimal placement, quantities, and sizes of those entries.
Rikhart
Rikhart
19
That new front wing is amazing...
newbie
newbie
there IS a limitation on the size of the DD inlet. it must shadow the rear suspension, and so the longer you make your forward, upper wishbone leg the bigger your DD inlet can be.
feynman
feynman
Rikhart wrote:That new front wing is amazing...
What new front wing? It hasn't been seen yet has it?
But new rear wing has ...
Old wing:
New Straight wing:
... always a slight disapointment when the hard-hearted laws of physics make a straight edge more efficient than some lovely curvy sweeps.
wouldnt the new shape make it more efficient to let the f duct blow on the first wing? then you will get a much lower point where the wing will stall reducing drag?
siskue2005
70
Old wing:
New Straight wing:
Yeah, i think the straight one is as efficient as the curved ones
As Mercedes/Brawn always had straight rear wing
newbie
newbie
the new rear wing has TWO inlets instead of the single inlet that the 2009 high-downforce rear wing had. look closely..
Holm86
247
newbie wrote:the new rear wing has TWO inlets instead of the single inlet that the 2009 high-downforce rear wing had. look closely..
two inlets?? how can this be done when only 2 wing elements is allowed?
Poleman
Its just the light reflection on the black coloured edge.
place 2 behind each other for example
newbie
newbie
the inlets are similar to those on the 2009 high-downforce RW, except that one is on the left side of the car and the other is on the right side. i havent seen any 100% clear image of the inlets but if my suspicion is correct it should be fairly obvious come tommorrow.
Holm86
247
newbie wrote:the inlets are similar to those on the 2009 high-downforce RW, except that one is on the left side of the car and the other is on the right side. i havent seen any 100% clear image of the inlets but if my suspicion is correct it should be fairly obvious come tommorrow.
Sorry i think i misunderstood what you ment. What you are talking about is what is visable right underneath the first "O" and the "N" in the vodafone logo right?
newbie
newbie
yup, thats it!
