That's pretty much it. It'll be good to see a top down comparrison. The Red Bull and Mclaren are very similar, go figure, and the Mercedes is more flowing, less curvy, due to the hot air exit starting sooner in the side pod.SectorOne wrote:Wow thank you Artur, basically everything i could ever ask for.
And thank you as well Sevach, it´s interesting studying the packaging of these cars.
Edit: yea seems Toro Rosso edges everyone with Merc, Bull, Macca trailing behind them.
The only diff between those three seems to be how tight they have pinched the hot air exit.
No it´s not. If it really was the case then Red Bull would not have beaten all Mercedes teams except one.giantfan10 wrote:this is primarily now an engine formula... prime example the 2014 red bull.
Ah! That's why every team pushes its own pod design to the point where cooling is seriously compromised in favour of aerodynamics!giantfan10 wrote:the car with the best undercut/overcut means absolutely nothing.
my point is and will remain deciding who has the best coke bottle or undercut will not determine the best or worst car in the 2015 championship.variante wrote:Ah! That's why every team pushes its own pod design to the point where cooling is seriously compromised in favour of aerodynamics!giantfan10 wrote:the car with the best undercut/overcut means absolutely nothing.
Sorry for the irony, but you should reconsider your position about aero importance in today's F1...prime example the 2014 RedBull...
