F14T- a cardboard model
kosioBG
86
Re: F14T- a cardboard model
Hi guys!
Here is my second report.
Inside the monocoque
To start, here are the pedals:
Here you can see the pedals mounted. Also, there's the map of Melbourne on the right side. And an additional reinforcement rib at the very front of this pic.
Next, the seat. It took me two attempts, but in the end I think it turned out nicely.
And here it is installed in place:
That's it for now and thanks for watching! New updates soon!
Cheers :D
kosioBG
86
Hi again, here is my 3rd report
Completing the chassis
To start, I had to close the cockpit. Since I'll never have such good access to it later, I made the steering wheel. If you look closely, you can see the display and rev ligths, the buttons and the gear paddles.
That done, I cut out the top of the monocoque (and nose)
and glued it in place:
Next, the turning vanes. Not much to say about them, but you can see a slot at the front end. Also, note the TV cameras on top. I had to cut a little hole in the cardboard for them.
And here it gets interesting. Sidepods. They consist of a layer of red on top and one black underneath, carefully shaped and curved.
Gluing them in place wasn't easy, because they were flexing in the opposite direction, but eventually I got it. Also, I added the white line.
Next, the head rest and protection + TV cameras
And the final thing I'll cover in this report is stickering. This time, I decided to print out the logos for more precision. I used Adobe Illustrator to prepare them- find the corresponding logo on the internet, trace it, change colours (if required) and then scale it. After printing, I cut them out, coloured the edges of the paper with a felt-tip pen (as Paul taught me) and glued them with a waterbased varnish that serves as glue. A layer of the same varnish followed. Next, I mounted the mirrors. Finally, I painted it with 2 layers of proper high gloss varnish. Here is the result:
I know that it isn't perfect, but I'm pretty satisfied with it. Next step- floor.
Comments are wellcome :D
Cheers :)
el-Magico
el-Magico
-10
Location: The number above shows the current temperature
Very nicely done!
Looking forward to the rest, good luck!
Quote of the year: "almost as sickening as the Velcro fluff under Lewis' cap..."
Alonso Fan
Beautiful, absolutely beautiful! Very well crafted and already an improvement on your previous model.
keep up the good work, I'm looking forward to the next report...
SHR Modding
Youtube
Twitter
Discord
Sound Developer for Reiza Studios
Sound Modder for Assetto Corsa
kosioBG
86
Hi there, time for the next report!
Floor
After completing the cahssis, I started manufacturing the floor.
It consists of three cardboard main pieces, each with a slightly different shape to shape the diffuser and the splitter.
Here they have become one:
Next, I added the details on top of the splitter (the vertical thing at the front to be added a bit later)
Next, the underside. Not many pics of that area, but still i got a shot of the wooden plank to use as reference. More info was to be found on the diff.
The barge boards and the vertical thing followed. The santander logo was also glued in place and varnished.
Even though some details are missing, I glued the chassis to the floor and added the vertical things at the end of the sidepods.
That's it for now. Next stop-gearbox. Luckily, there are some nice shots of it on the forum to help :)
Cheeres :D and don't forget to check for updates
PP enjoy Melbourne tomorrow
Alonso Fan
Looking good :)
just one question, how are you looking to shape the engine cover and exhaust outlet/cooling outlets ?
SHR Modding
Youtube
Twitter
Discord
kosioBG
86
not completely sure yet, but it will be something similar to my previous car. I'm planning to use 3 cardboard pieces and their overlapping shall be covered by logos. after completing the gearbox, i'll be at it
idfx
Nice.
You know the software: Pepakura Designer ?
kosioBG
86
wow haven't seen it, will definitely look into it!
idfx
is a software papercraft.
Imagem Example
project ferrari: http://visualspicer.com/personal-work/f ... aft-racer/
Site: http://www.tamasoft.co.jp/pepakura-en/
idfx
is a software papercraft. you can create a model in 3d, export and edit to your papercraft.
kosioBG
86
Hi guys, time for my next report.
Gearbox, Exhaust and Bodywork
After I complete the floor of a car, I construct the gearbox. Here you can see the main piece:
Here it's folded and the mounting holes for the suspension are added:
Here is the completed gearbox, with the carbon texture, the top wishbone rear mounting part and the spike.
Mounted to the floor. Sadly, not in focus.
Here you can see the underside. The place where the rear jack lifts the car is also there. Overall, that area turned out pretty good.
Adding the exhaust was quite straightforward, not much to say about it. You can also see the connection detail from the floor to the gourney flap over the diffuser.
Now the bodywork was a torture to get done. I started with the central element, which took me 3 times to get right.
The side panels are the weakest point of the car. Their shape took about 8 attempts. In the end, its shape wasn't bad. The only problem is the large and visible gap between it and the sidepods. Anyway:
I hoped though that adding the decals and the carbon fibre texture would cover things a bit. That was true, only the gap remained exposed. The reason I'm not that worried though is that Paul had that same problem with his RB7. Also note the vertical fin on top.
And the (almost) finished bodywork. Only a layer of varnish is missing.
Despite the other problems, the undercut is nice.
And the whole car after almost a month of construction:
Next step: Suspension!
Cheers guys :D
Alonso Fan
Looks cool!
pity about the gap though.
SHR Modding
Youtube
Twitter
Discord
el-Magico
el-Magico
-10
Well done, looks great.. Indeed a pity about the gaps.. Isn't it possible to fill it up someway?
Good luck!
Alonso Fan
You could glue a thin strip along the gap, may be tricky though.
then go over it with another layer of varnish, the joint shouldn't be visible then. Although you would have to re stick the ups logo
SHR Modding
Youtube
Twitter
Discord
