CAEdevice wrote:Do you mean that your numbers are about dr=1000N and df=7500N? Impressive! I could only obtain a df/dr ratio around 4.7.
Efficiency of 7.5? Unfortunately not... Drag is hopefully low enough, but downforce comes down as well...
An efficiency of 4.7 is only 0.2 better than Mantium's high downforce configuration, and 0.3 better than my first high Df beast: you've got to improve that value! Use less wing, maybe... Let's wait for the race to discuss about the best solutions to adopt, anyway.
About efficiency: one of the most difficult aspects of these "very high efficiency" races is to understand where to stop cutting downforce in order to decrease drag. More specifically, there is a configuration of maximum efficiency (which doesn't correspond to the lowest drag setup!), that we should seek and which is very hard to achieve...
Also, it's interesting to notice that if you manage to keep constant your efficiency and increase downforce at the same time, you get slightly better laptimes (given the current track configuration and engine performance). Problem is that at high levels of downforce, an incresingly inefficient amount of drag is required... An good challenge for us!
Finally, let's not forget that, for the incoming races, we could achieve the same laptime improvement either cutting 1 point of drag or adding 5 points of downforce!!
