Tom wrote:... The only problem is getting enough air through the hole to go down the corridor...
I believe the distance does not depend on the amount of air, but on the impulse you give to the "rolling wave". It is self-sustained, like the
soliton wave mentioned in the reference you provide.
A soliton is a different kind of wave, but its dynamic is similar: the longer wavelengths of the wave and the shorter ones interact to shorten and lenghten their wavelenght respectively, interchanging places: the longer ones become shorter and viceversa.
They can keep doing this for a long time. This way, the wave never changes and keep moving along without desintegrating, like normal waves, where the shorter wavelengths move faster and "left the wave behind".
This kind of self-sustaining waves can travel far: the first soliton transmited over a fiber-optic network reached 14.000 km. The first application of a soliton over a commercial Internet network was in 2001.
I swear I saw one in the Canal del Dique, in Colombia, between Cartagena and the Magdalena River. At least, I saw a wave (I was standing in the road at the side of the river) that moved for a kilometer or more on the channel, upriver, like Jhon Scott Russell once did.
Unfortunately, in your vortex cannon, the ring has friction with the air as it "rolls on itself" and this is what desintegrates it. But the problem, I believe, that you confront is to move fast enough the diaphragm, not to move a lot of air (not that they are not related somehow). This is why the vortex cannon using a solenoid impulsing a diaphragm can give so much energy to the "wave".
I cannot resist to mention that we have a vortex box, that uses dry ice, at
Maloka, in Bogotá, a permanent science display, and it is probably one of the most popular "attractions".
This photo shows Bogota's Maloka. I worked on their computer network, when it was built: the semi-sphere is an I-Max theater and the crystal structures are the entrances. The whole thing is underground. It is the most beautiful science divulgation site I've seen.
