...is essentially the same thing as...2014 F1 Technical Regulations wrote:5.5.1 The only means by which the driver may control acceleration torque to the driven wheels is via a single chassis mounted foot (accelerator) pedal.
...except that it incorporates KERS and HERS to prevent them from being used for propulsion independent of the engine. In other words, it means torque from all sources must be applied concurrently if applied at all.2012 F1 Technical Regulations wrote:5.5.1 The only means by which the driver may control the engine torque is via a single chassis mounted foot (accelerator) pedal.
Further...
...only applies to individual power unit torque maps, not overall power unit torque. Engine mapping, by the way, is not limited in 2014...yet.2014 F1 Technical Regulations wrote:5.5.3 The minimum and maximum accelerator pedal travel positions must correspond to the minimum and maximum available torque with the currently selected power unit torque map.
