Conceptual wrote: If a flywheel is in the nose, while laying horizontally, would it help to stabilize the up and down pitch movement?
hmmm.... that sounds like an 'aerodynamic device' !
They can do what you suggest. The rules limit the maximum output, but do not limit its use otherwise. Using the system to stretch the pit window via fuel conservation rather than an increase in total power is a strategy that could be employed.bazanaius wrote:Random question about KERS - do they have to apply the kers at 60kw, or can they 'dumb it down' but run it for longer - say 30kw for 13.4s? Not sure whether this would be useful, just trying to clarify rules.
Maybe if this is the case they can adjust it for each corner - take it as an energy problem rather than a power one and optimise over a lap given track conditions or whatever other variables they might want.
B
See my post above about putting a mechanical device in the nose.Conceptual wrote:Are you guessing at the amperage requirements of the Williams KERS system, or do you have some actual information leading to your dismissal of this idea? I have seen some rather large machinery that uses 480v 3phase, and run on 8 gague wire over a 150ft run.DaveKillens wrote:If the gyrscopic forces were powerful, it would inhibit the chassis from rolling and pitching, but have zero efect if the motion was straight up and down.Michiba wrote:thanks for the explanation... still trying to get my head around it though.
On a side note, if such a system were in place, theoretically would the gyroscopic forces be able to 'hold' the car in midair after it goes over a curb/bump momentarily? In practice, I assume the downforce would counter that if it were the case though.
One additional handicap is the added weight of the electrical cables. They would have to carry high amperage, which would make them large gauge. Such large gauge copper wire would add up in the weight department. For instance, 10 ga. copper is 31.8 feet per pound. So roughly, expect adding at least 2 kilos for wire if you intend to run it to the nose. Considering engineers sweat the fine details just to remove a gram here and there, and this makes for a difficult decision.
I think for the 10 feet or so that would be needed, 10/3 aluminum MC cable should be fine.
Unless, of course, you actually have some amperage numbers from WIlliams?
Also: Why would it slice the drivers feet? It is a fully enclosed, vacuum sealed "disc" casing. Even in the event of catastrophic failure, I believe that Williams claims 100% containment.
The question is: Would it be advantageous to place the flywheel low and in the front (nosecone, or under the drivers feet) to control pitch? Or would its placement be necessitated by the pitch center of the car?
Thanks!
AFAIK the Williams implementation uses no mechanical linkage to the flywheel,it's all electrical.Professor wrote:A basic mechanical problem with the flywheel in the nose is how do you couple it to the freaking drivetrain? It must be driven by a mechanical system. To concern one's self with the cables ignores the mechanical connections. How do you connect it mechanically?
