BAR Honda's front differential
Conceptual
Conceptual
Does anyone else remember when BAR showed up at a race in 2005ish with the front differential that the stewards made them remove before racing? I can't seem to find any info about it. Does anyone have any links?
Thanks,
Chris
PNSD
PNSD
Re: BAR Honda's front differential
Hockenhiem 2004 ? Front torque transfer or something ?
Nonetheless, Buttons pace still owned everyones but Micheals :p
bar555
bar555
Check this :arrow: http://www.formula1.com/news/technical/2004/725/53.html
It was first introduced in 1999 by Benetton and was originally named as
Front Torque Transfer FTT
BAR006 in 2004 made a mechanical copy of that system and named it Front Clutch Package FCP
Future is like walking into past......
Blog : http://formula1techandart.wordpress.com/
Twitter :http://twitter.com/bar555onF1
Belatti
Belatti
That is not a proper technical analisys, is not technical and is not an analisys. It only says its a device to help stability while braking.
Appart from that there is a picture that shows it location on the rear and another picture of the front, so where the hell is the device located and how does it work? :evil:
These F1.com "official" guys have tons to learn from F1T !
scarbs
scarbs
393
Race car engineering magazine had a interview with Geoff Willis on the FCP. I don’t have the copy to hand, but basically the set up whether in its original electronic aided form or its later mechanical set up was used to improve corner entry stability, both by preventing front wheel locking, but also to induce a turning moment across the front axle. Quite how this was ever allowed to race is questionable, but the device was allowed to run, then prevented in its electronic form. In its final mechanical format, the team would have been allowed to race it the next year, but a deal with other teams on limiting front wing flex was agreed and the unit was never aced again.
Scarbs
mep
29
Sounds a bit like the McLaren brake system, which was used 1997 and 1998.
bar555
bar555
During a turn Urot1 < Urot2
CFP tries to reduse the speed difference between the front external and internal wheels
A picture of this system
Conceptual
Conceptual
Hmmm,
With the new KERS systems on the horizon, does this device now have a way back into F1?
Thanks for the info!
Chris
