The reason I ask is because I was driving extremely hard up in some mountain roads and I over-cooked the brakes, they faded and were smelling horrible. It got to the point where braking was almost gone.
So what are some possible effects on the entire system? Will the pads need to be replaced due to possible glazing or whatnot? Will the brake fluid need to be replaced? Or what about the calipers? Any damage that might have happened internally? Or will everything be fine with no consequences hopefully?
The calipers are two piston front/one piston rear, with ventillated discs, and normal pads (everything OEM besides pads).
Thanks in advance.
1000th post in almost 2 years!
