is this seamless shift gearbox or am i wrong beacuse when engine changes gear their is a pause in the spray i though the engine didnt stop or is that the sequentioal gearbox?
http://www.youtube.com/watch?v=y2iBbwocYZw
Zero shift is a company manufacturing a novel syncro assembly.Cyco wrote:Auto,
The ZeroShift companies boxes are so close that they may as well be. They just need improved durability to have them in general use road cars
Imagineer wrote:Zeroshift is not manufacturing anything particularly not "novel syncro assemblies".
There are many buzz words to describe seamless shift gearboxes, like zero shift, quick shift or even trigger shift. It all boils down to changing gear without interrupting the engine torque to the wheels. I doubt any racing driver in any form of motor vehicle could achieve such a phenomenon.
With a stepped gearbox, it is impossible to transfer torque during the shift.(by current conventional means).Imagineer wrote:I am watching carefully and I cannot see a syncro. Do you know what a syncro mesh gearbox is and how it works beause I do!
I am not disputing their claim as I have never experienced a Zeroshift.
I was merely pointing out the definition of a seamless shiftImagineer wrote:It all boils down to changing gear without interrupting the engine torque to the wheels.quote]
Thanks
That's a F1 engine (mid nineties Renault V10) run on an engine dyno without a gearbox. It's probably an electric dynomometer as these are excellent for track simulation (which is what is done in this clip).adam2007 wrote:is this seamless shift gearbox or am i wrong beacuse when engine changes gear their is a pause in the spray i though the engine didnt stop or is that the sequentioal gearbox?
doubt is was mid nineties v10 was used untill 2005 could be anytimeEdis wrote:That's a F1 engine (mid nineties Renault V10) run on an engine dyno without a gearbox. It's probably an electric dynomometer as these are excellent for track simulation (which is what is done in this clip).adam2007 wrote:is this seamless shift gearbox or am i wrong beacuse when engine changes gear their is a pause in the spray i though the engine didnt stop or is that the sequentioal gearbox?
I think the engine in the clip is a Renault RS7 which was used back in 1995.adam2007 wrote:doubt is was mid nineties v10 was used untill 2005 could be anytimeEdis wrote:That's a F1 engine (mid nineties Renault V10) run on an engine dyno without a gearbox. It's probably an electric dynomometer as these are excellent for track simulation (which is what is done in this clip).adam2007 wrote:is this seamless shift gearbox or am i wrong beacuse when engine changes gear their is a pause in the spray i though the engine didnt stop or is that the sequentioal gearbox?
