Compression ratio
mep
29
Compression ratio
What compression ratios are current (F1) engines running?
A colleague told me last week that otto-engines for motorcycles can run compression ratios up to 1:13.
I thought that this would lead to high peak pressures because of the isochoric process during combustion.
There must be a point(compression ratio wise) where the peak pressure goes over the peak pressure of a diesel engine.
I think peak pressure depends on engine revolutions. Because the time for combustion will go into expansion phase of volume (piston already going back) and therefore you get more of the isobaric process (diesel like).
Edis
Edis
59
Re: Compression ratio
I would suspect current F1 engines use compression ratios around 12-13:1. As F1 engines use very short strokes it is difficult to reach a high compression without blocking the combustion chamber and the flow around the valves.
Peak pressures are around 110 bar, passenger car diesels are around 180 bar these days and commercials diesels go as high as 200-250 bar.
With both the diesel and the spark ignition engine the piston moves during heat addition changing the volume which means the heat addition isn't fully isochoric, and they are in practice not that different when they operate at high load. At low load the diesel has a rapid pressure increase early in the combustion phase which results in a small pressure peak before the main peak. In theory this is interpreted as the Seiliger cycle with constant volume and constant pressure heat addition. The reality is something in between. Both for diesel and gasoline engines.
By the way, the racing diesels that are used on Le Mans doesn't use much higher compression ratios, 14-15:1 or something like that.
autogyro
autogyro
Helped build a spark ignition engine for touring cars, designed to run on LPG.
It had a compression ratio of 15.5:1 and could run well at 17:1
Petrol is nowhere near the best ic fuel.
LPG needs no additives to prevent detonation and neither does ethanol.
You want power, just keep adding nitro to methanol, I used to wear a special wizards hat when doing that.
Reason: Removed ignition of a possible rant
WhiteBlue
92
Dual fuel engines reach very high compression ratios as well and deliver high efficiencies. For instance you can run a diesel engine with LPG and inject a tiny amount of diesel or bio oil to start the self combustion.
strad
117
No it doesn't require additives...It requires twice as much volume in the case of alcohol and even more in the case of LPG.
One can run alcohol at extreme compression ratios but fuel mileage sucks.
I would agree that F1 engines probably fall into the 12 - 13 to 1 range...I don't think shrouding of the valves is much of a problem with the straight shot intake tracks they run..but piston top shape could play havoc with the combustion and swirl...not to mention the weight,,,you seen these pistons? there is no real piston,,just a place for a ring or two and a top.
Sir Stirling Moss
Jersey Tom
Jersey Tom
Sport bikes on pump gas already run compression ratios up to 12.5:1, and I'm fairly sure race bikes are in the 14.5:1 range (though I'd have to check).
I'd have to imagine F1 is in that range. Then again engines aren't my strong point.
CMSMJ1
CMSMJ1
You are right JT.
My race bike runs 12.5:1 and it is 21 years old..
If I could afford some new Cosworth pistons for my bike I would get a 13.5:1 ratio no problems and could then also skim the head to improve that still.
I run 98RON fuel unless I can get my hands on some BP Race 102.
IMPERATOR REX ANGLORUM
232
Jersey Tom wrote:Sport bikes on pump gas already run compression ratios up to 12.5:1, and I'm fairly sure race bikes are in the 14.5:1 range (though I'd have to check).
I believe the ferrari 458 italia has a compression ratio of 12.5:1 as well.
Not bad for a production car.
strad
117
Stock Porsche' run like 13 to 1
Sir Stirling Moss
Agenda_Is_Incorrect
Agenda_Is_Incorrect
-5
autogyro wrote:I used to wear a special wizards hat when doing that.
LPG is in general extracted by oil companies and even sold by them and so is ethanol in most countries that it is sold to the public. Both have problems and specially LPG has with packaging and lubrification. Coming from a country with ethanol I can also say for sure mileage is bad even with high compression, making it unusable as a replacement for oil in the current stage of biofuels. Stop saying nonsense and taking topics out of the way to promote your religion. Reported again. Moderators please fell free to edit this post after solving this topic problem.
Reason: Removed smell of personal offence
I've been censored by a moderation team that rather see people dying and being shot at terrorist attacks than allowing people to speak the truth. That's racist apparently.
God made Trump win for a reason.
diosol
diosol
mep wrote:What compression ratios are current (F1) engines running?
We run compression ratio of 16,8:1 in our engine with ordinary 95 octane gasoline. http://remmi-team.com/content/vehicles/r7/ How do you think about that?
autogyro
autogyro
Superb result. Perhaps you can explain to some of the posters on here that compression ratio does not on its own define combustion chamber pressure.
Also that simplistic references to different fuels means absolutely nothing.
diosol
diosol
autogyro wrote:
diosol wrote:We run compression ratio of 16,8:1 in our engine with ordinary 95 octane gasoline. http://remmi-team.com/content/vehicles/r7/ How do you think about that?
http://forums.evans-tuning.com/viewtopic.php?t=136
http://en.wikipedia.org/wiki/Octane_rating
Octane rating does not relate to the energy content of the fuel (see heating value). It is only a measure of the fuel's tendency to burn in a controlled manner, rather than exploding in an uncontrolled manner.
Our engines cylinder stats:
Bore x Stroke / Volume
27,7 x 70 mm / 42 cm3
That's a quite a bit longer stroke than usually. Do any gurus know why we have do it this way?
mep
29
Quite interesting. What is the reason for it?
Holm86
249
Perhaps because of the very high turbo pressure??
