My friend who has only just started watching F1 asked me why there are 2 clutch paddles on the steering wheel and how are they used. I think i know, but i canted to check on here if i am correct
For this example i'll name the clutch paddles 'Clutch 1' and Clutch 2'. This is how i explained it to my friend......
Both clutch paddles do exactly the same thing but they use 2 at the start to help with quick launches. Clutch 1 is pulled fully in 100%, while Clutch 2 is set to a position that has been pre-determined to give the optimum amount of slip (i said to my friend its a bit like the biting point in a road car).
Anyway, when you pull up at your grid box, you cover the brake, pull in you clutch's and select 1st gear and raise the revs. When the lights go out for the race to start, the driver 'dumps' Clutch 1 (this is to aid the super fast launch while reducing the likely hood of stalling, which would be grater if you used just one clutch) and you are now running on Clutch 2 which is at the point of optimum slip and launches the car off the line. Then once you started moving you feed the rest of Clutch 2 out, like the way you do when moving off in a road car. Then thats you off and moving speeding up towards 2nd gear
Is this the way the clutches are used at the starts? I know i''ve missed out a couple of things fro the start process, but this is because the topic is more about how to use the clutch(s). I also know that there is only one actual clutch......its just its got 2 paddles that operate it
