Carlos wrote:I think the reference to "real tyres" means the very wide slicks from years ago. I like this idea, along with widening the track of F1 cars, more liberal udertray aero and less body and wing aero. Just as electrostatic shock absorbers have fluid that changes viscosity with electric current and active elctronics, polymer cording inn the side walls of tyres could do the same, which would alter the slip/scrub angles in cornering and on uneven road surfaces. With very stiff suspension, many suggest that the tyre and its sidewall flexure is actually part of the "supension package." The evolution of F1 rules over the next 6 o years will be very interesting.
That's exactly what I'm talking about. Wider tires, and looser Aero rules.
Right now, teams are running hige rear wings and lots of body work that totally screws up the wake for following cars. This is their only option under the current ruleset.
If the FIA loosened up the Aero rules, teams could run better undertrays, which, since they're incredibly efficient, would eliminate the need for all the body work and for the agressive rear wings.
The FIA's aero regulations simply push the Aero to be MORE disruptive. The FIA has no idea how to get what it wants done. They changed engines to V8's hoping to lower speed and reduce cost. What happened? Teams pent MORE money redesigning new engines, and the cars are virtually the same speed.
The FIA did the two race engine thing to reduce costs. What happened? Less engines had to be built, saving money, but then more money had to be spent testing more engines to
improve reliability. Teams also had to pour a LOT more engineering into the engine so they'd last. Result? Cost was HIGHER, exactly what they didn't want to do.
The FIA should shut its mouth and solicit ideas from engineers (retired or active) on how to introduce regulations. As it stands, they're a bunch of business wankers who want to be praised at cocktail parties for having "changed the sport forever" when they in fact are ruining it.
This more towards no Aero is the wrong direction. Aero is NEEDED for breaking and stability. No power will be put down without Aero. All the runoffs wil need to be extended as removing aero will drastically increase stopping distances.
Lastly, there's the FIA's eco-bullshit. All this want for green cars running on bio diesel hybrids. Its goddamn F1, we've no desire to watch a flock of Prius' run around track.
If the goal is redducing C02, then lets have no racing at all, which is just a waste of energy to begin with. I am sure teams could make greater strides towards reducing C02 if they withdrew from F1 and spend 100% of the money on fuel saving technologies . . .
I absolutely desise the FIA. It's a worthless organization.
