http://www.formula1.com/insight/rulesan ... 4/498.htmlFormula One cars must have four, uncovered wheels, all made of the same metallic material. Front wheels must be between 305 and 355mm wide, the rears between 365 and 380mm.
With tyres fitted the wheels must be no more than 660mm in diameter (670mm with wet-weather tyres). Measurements are taken with tyres inflated to 1.4 bar.
FIA Regulations in detail
ARTICLE 12: WHEELS AND TYRES
12.1 Location:
Wheels must be external to the bodywork in plan view, with the rear aerodynamic device removed.
12.2 Number of wheels:
The number of wheels is fixed at four.
12.3 Wheel material:
All wheels must be made from an homogeneous metallic material.
12.4 Wheel dimensions:
12.4.1 Complete wheel width must lie between 305 and 355mm when fitted to the front of the car and between 365 and 380mm when fitted to the rear.
12.4.2 Complete wheel diameter must not exceed 660mm when fitted with dry-weather tyres or 670mm when fitted with wet-weather tyres.
12.4.3 Complete wheel width and diameter will be measured horizontally at axle height, with the wheel held in a vertical position and when fitted with new tyres inflated to 1.4 bar.
12.4.4 Wheel bead diameter must lie between 328 and 332mm.
