I post just to clarify that you do not need an object to spin for the dimples to work.
The dimples do not work because they diminish drag, but because they create turbulent flow. The turbulent flow has more energy, so the flow separation behind the golf ball is smaller. They diminish what's called pressure drag, caused by a relative "void" behind the ball.
So, dimples are not that good for objects that have small flow separation, like wings or F1 cars. They work well in "blunt" objects, like golf ballls. Check this, taken from one of the threads mentioned by Belatti:
For wings and the such, you use vortex generators to diminish drag, like those serrated edges, taken from the same thread:
Serrated Gurney flap (the small vertical plate at the back edge of the wing)
Serrated windscreen (the metallic plate with holes in front of the steering wheel)
Sorry for the repetition, but I'm positive most people don't follow links in threads.
Finally, I think Junior is taking risks and spinning because he must be a little desperate. That's nothing to be ashamed of.
NOTE: if this thread "drags" on, I think it's better to incorporate it into the previous ones.
