Sad character that I am, I happened to be thinking about brakes the other day. To an extent this was fuelled by the thread about using the wheels to generate down/side/up force I got to thinking about how much energy the brakes on an F1 car must dissipate (bear with me, it's worth it!!).
Take a circuit like Monza, or Montreal; at the big stops the cars must brake from somethingaround 340km/h to about 80km/h - now think about how much energy that is, and most of it must be lost through the brakes.
If one uses the formula for kinetic energy (KE=1/2 mv^2) they must lose 260km/h, now assume that the car weighs 650kg (after all it has some fuel on), plug the figures into the formula and it transpires that the car must shed approximately 1.7 Megajoules of energy in about 2-3 seconds. To put that into context, that's about the same anoutn of energy you get from a 1 bar electric fire running for about 30 minutes... no wonder the brakes glow.... and they have to do those type of stops twice per lap and a few lesser ones on the other corners. It's quite an engineering challenge to lose that amount of heat in a very short time.
Now, some of that energy will be dissipated via the downforce and drag, but the majority has to be shed as heat and that means brakes and tyres - That's one reason why the wheels have enough work to do without generating down/side/up force - I think this is one more reason why I love F1 - just about everything on these cars is amazing...
