THIS WAS COPIED HERE BY DELUGE AND THIS THREAD WAS STARTED BY DELUGE. IT WAS ORIGINALLY POSTED IN THE ENGINE/DRIVE TRAIN FORUM BY Ogami
BY Ogami
I'll sum up my views on the chassis side.
-50% Reduction in drag:
I find it quite good actually, i think not going for this was a little bit of illusory as this is already the trend.
To do it of course radical concept are to be allowed, the main one being the moveable aeros and the second the Ground effects and thus removal of the flat bottom, both i think are great.
One thing i like about that departement is that while the 50% reduction will occur only in straight, a significant part of the proposal is about managing better laminar aerodynamic efficiency mainly by the means of morphing or plasma.
This will help preserving the downforce while decreasing the drag wich will surely lead to very efficient cars, maybe we'll see the comeback of very high lift to drag ratio cars like the GE era ones.
-50% reduction in downforce over 2009 levels(themselves being 50% less than the 2007 ones):
This proposition seems a bit scary until you get that this reduction is aimed for straights and high speeds thus it is a maximum downforce level achievable.
Because of moveable/active aeros the downforce in low speed and medium corner will increase over the current levels and the tyre efficiency is to be increased by 3% added to new suspensions possibilites all in one the plans are to have decreased lap time over 2009, the question will be what will be thoses lap times?
In anyway the maximum downforce level for 2009 is 1250kg.
For a 5G turn at 250km/h (like magny cours turns 6 and 7 or Corpse at silverstone) it requires actually about the 1600 kg of downforce but all depends on the Tyre efficiency and the weight on the tyres so because thoses points are to be increase in efficiency i'm not that worried about high speed possibilities.
As far as lateral acceleration are concerned, the minimal weight system is to be removed so it seems cars are to be lighter (but the drivetrain proposal is conflicting on this point as the drivetraine will be heavier).
If car are lighter= more lateral acceleration aviable.
-Overtaking:
the move for adaptative aeros is definitevely the way to go if you want to have long straight low drag/low downforce and in corners high downforce with still low drag.
The frequencies choosen by the FIA are quite okay and the ride height adjustement is quite okay.
Now on a personnal note i'd like to see pilots being able to control even on a linear basis the set ups, choosing in corner between high downforce/more drag or less dowforce/less drag.
As an auto racing corner is not regular (requires different G's) this could be interesting.[/b]
