Picked up the mag today and its a pretty intresting article.
Areas in red are the disputed areas:
Williams FW31:
Toyota TF109:
To what the Renault R29 diffuser ls like:
And the McLaren MP4-34:
What the rules say:
3.5 Width behind the rear wheel centre line :
3.5.1 The width of bodywork behind the rear wheel centre line and less than 200mm above the reference plane must not exceed 1000mm.
3.5.2 The width of bodywork behind the rear wheel centre line and more than 200mm above the reference plane must not exceed 750mm.
3.12 Bodywork facing the ground :
3.12.1 All sprung parts of the car situated from 330mm behind the front wheel centre line to the rear wheel centre line, and which are visible from underneath, must form surfaces which lie on one of two parallel planes, the reference plane or the step plane. This does not apply to any parts of rear view mirrors which are visible, provided each of these areas does not exceed 12000mm² when projected to a horizontal plane above the car, or to any parts of the panels referred to in Article 15.4.7.
The step plane must be 50mm above the reference plane.
3.12.2 Additionally, the surface formed by all parts lying on the reference plane must :
- extend from a point lying 330mm behind the front wheel centre line to the centre line of the rear wheels;
- have minimum and maximum widths of 300mm and 500mm respectively ;
- be symmetrical about the centre line of the car ;
- have a 50mm radius (+/-2mm) on each front corner when viewed from directly beneath the car, this being applied after the surface has been defined.
3.12.3 The surface lying on the reference plane must be joined around its periphery to the surfaces lying on the step plane by a vertical transition. If there is no surface visible on the step plane vertically above any point around the periphery of the reference plane, this transition is not necessary.
3.12.4 The peripheries of the surfaces lying on the reference and step planes may be curved upwards with maximum radii of 25mm and 50mm respectively. Where the vertical transition meets the surfaces on the step plane a radius, no greater than 25mm, is permitted.
A radius in this context will be considered as an arc applied perpendicular to the periphery and tangential to both surfaces.
The surface lying on the reference plane, the surfaces lying on the step plane, the vertical transitions between them and any surfaces rearward of the surfaces lying on the reference or step planes, must first be fully defined before any radius can be applied or the skid block fitted. Any radius applied is still considered part of the relevant surface.
3.12.5 All parts lying on the reference and step planes, in addition to the transition between the two planes, must produce uniform, solid, hard, continuous, rigid (no degree of freedom in relation to the body/chassis unit), impervious surfaces under all circumstances.
Fully enclosed holes are permitted in the surfaces lying on the reference and step planes provided no part of the car is visible through them when viewed from directly below.
3.12.6 To help overcome any possible manufacturing problems, and not to permit any design which may contravene any part of these regulations, dimensional tolerances are permitted on bodywork situated between a point lying 330mm behind the front wheel centre line and the rear wheel centre line. A vertical tolerance of +/- 5mm is permissible across the surfaces lying on the reference and step planes and a horizontal tolerance of 5mm is permitted when assessing whether a surface is visible from beneath the car.
3.12.7 No bodywork which is visible from beneath the car and which lies between the rear wheel centre line and a point 350mm rearward of it may be more than 175mm above the reference plane. Any intersection of the surfaces in this area with a lateral or longitudinal vertical plane should form one continuous line which is visible from beneath the car. A single break in the surface is permitted solely to allow the minimum required access for the device referred to in Article 5.15.
Additionally, any bodywork in this area must produce uniform, solid, hard, continuous, rigid (no degree of freedom in relation to the body/chassis unit), impervious surfaces under all circumstances.
3.12.8 All sprung parts of the car situated behind the rear wheel centre line, which are visible from underneath and are more than 250mm from the centre line of the car, must be at least 50mm above the reference plane.
Basically it all revolves arround a maximum height of 175mm line, that the red sections are above and could provide a performance advantage.
I cant find a pic or the Ferarri or the BMW Sauber F1.09 diffusers.
