it possible that all the time we spend on the mclaren's rear wing
that red bull actually had a blown diffuser that stalls at high speeds?
the difference is that it uses exhaust gas which varies with rpm not air speed
that could explain why red bull didn't have a ride height system and yet it is able to be low enough to scrape the ground at quali and do fine in the race
i mean there must be a point where the air speed at the bottom is so high compared to the air at the back that it essentially starts to stall. and since diffuser has little drag it doesnt really increase top speed that much but increase the L/D ratio and since it only works at higher rpm it basically become like an aero traction control (quote by lewis they have twice as much downforce)
the L/D ratio which i think is boosted....applies to mclaren too. when you introduce high speed air to the bottom of the wing it will increase downforce and when the wing comes to a stage where it creates too much drag it starts to stall.
the ride height issue is what i thought supported this idea. since diffuser has the highest L/D ratio you will reduce more downforce per drag when stalled, so increasing ride height with very little top speed gained.
what are your thoughts??? possible?
