First you have to understand what does the roll center height causes to know where do you want it.
To make it simple lets quote good ol Millikens:
Now be may have 4 basic positions:
1) Roll center height (from now on RCH) = center of gravity (CoG)
No pivoting here, it means that there is no roll. Its like trying to spin a door applying force in the hinge. The car is turning, lateral force is applied, but there is no roll. Hence, all the force is "catched" by the wishbones. This makes the car as hard as a rock, as spring/dampers doesnt work here.
Its good for nothing.
2) RCH between CoG and the ground. Depending the percentage of that height you distribute how much force goes through the wishbones and how much through the spring/dampers. The range between 15% and 30% of RCH compared to CoG is the most common place to locate it in many racing cars.
3) RCH = ground height. All the lateral forces passes from the chasis to the wheels throught dampers/springs, so virtually the wishbones makes no force under pure lateral load condition.
4) RCH below ground. More force than whats actually transferred passes through the spring/dampers, so that the wishbones is loaded unders "a negative" force. This means outer top wishbone for example is not under compresion, but under traction.
This is the case of tourism racing cars that have to maintain the suspension geometry from the original street car when you reduce their ride height, there you have to find the best compromise between what you gain from aero and reduced CoG height and what you loose for poor suspension geometry. Here you dont have jacking, but the contrary. Also it is the case of heavily "tuned" street cars... puaj!!!...
I think I gave you the elements for you to figure out why you wouldnt locate it there or near the center of gravity...
