marcush. wrote:The aero setup of the car is optimised for the dry conditions so in wet weather you will not see the same downforce simply because of the lower speeds.
You would run ALOT more wing in the rain if you could ...in effect totally different profiles with much more camber if that was a possibility.
So in effect the mechanical side of the car is getting upper hand in the equation because of the lower speeds -which place more emphasis on mechancal grip anyways and the aero working outside their window.
Don´t forget the rain tyres have more diameter so you will instantly move your front wing and undefloor say 5mm higher than optimum according to your aeromap.
come to this you will not be able to brake as hard because the grip is simply not there so you will not get the weight transfer so the car will not assume the rake under braking so potentially more downforce loss compared to dry conditions..
Actually, the braking G is the least effected of the "G" circle in the rain. With a good set of rain tires, the braking is very close to the dry braking G. As you increase the downforce, due to rain, it is relative to the drag produced when off throttle (even at a lower top speed). Just means the braking is a shorter distance but the G's produced are relatively close to dry braking G's.
The lateral G is the greatest reduction of G force in the rain and has the most direct effect on weight transfer. Hence the reason for removing ARB's, softening spring rates and rising the ride height (mostly for hydroplaning of the bottom of the car in puddles) and enable a "
greater amount of weight transfer" to make up for the lack of G.
"Driving a car as fast as possible (in a race) is all about maintaining the highest possible acceleration level in the appropriate direction." Peter Wright,Techical Director, Team Lotus
