F1 hub coating
da9
da9
F1 hub coating
Hey guys - does anyone know what sort of coating the F1 teams put on their hubs? They have a shiny brownish-purply coating. I think it's some sort of black-oxide but I don't know.
Any pointers appreciated, thanks!
furious_g
furious_g
Re: F1 hub coating
I'm keen to know too! I thik it's the same stuff the use on the drive shafts.
da9
da9
Re: F1 hub coating
You're right. I've held both of them and it appears to be the same coating.
hardingfv32
hardingfv32
Re: F1 hub coating
Anodic treatment in sulfuric acid results in a pronounced deep blue to purple oxide coating on titanium. (per finishing.com)
Brian
Jersey Tom
Jersey Tom
Re: F1 hub coating
Black oxide
furious_g
furious_g
Re: F1 hub coating
hardingfv32 wrote:Anodic treatment in sulfuric acid results in a pronounced deep blue to purple oxide coating on titanium. (per finishing.com)
I could be wrong, but I would doubt the drive shafts are titanium.
riff_raff
riff_raff
Re: F1 hub coating
F1 half shafts and stub axles would be titanium. The coating is likely anodic.
http://tiodize.com/anodizing.html
While titanium has excellent natural corrosion resistance, it also tends to gall/fret under contact. So wherever it has a loaded surface contact, like a spline or a thread, it must be hard coated to reduce galling.
A: Start with a large one!"
Jersey Tom
Jersey Tom
Re: F1 hub coating
I'd still bet the hubs and axles are 300M or 4340 and black oxide coated
da9
da9
Re: F1 hub coating
Jersey Tom wrote:I'd still bet the hubs and axles are 300M or 4340 and black oxide coated
Tom's right, the hubs and axles are indeed 300M. At least that's what the hub machine shop told me. Those things are freaking LIGHT too. The F1 axles are phenomenally lightweight; 2 of the F1 axles is heavier than one of our FSAE axles.
I'll look around Portland and see what the coating vendors can tell me. The only black oxide I've dealt with is a really nasty looking coating. The F1 hubs and drive shafts had nearly mirror finishes.
hardingfv32
hardingfv32
Re: F1 hub coating
Have both front and rear axles from the 2006-2008 time period and they are both titanium. No reason that the axles would not also be titanium.
Brian
da9
da9
Re: F1 hub coating
What alloy of Ti? I don't think Ti is hard enough to be used on the wheel bearing races and CV races, which can be machined straight on a 300M steel hub.
DaveW
DaveW
239
Re: F1 hub coating
Semantics? I believe uprights would have been Ti in 2007, spindles (as per OP's illustration) will be steel. It is hard to believe that drive shafts would be made from anything other than steel.
Re: F1 hub coating
Re: F1 hub coating
my take on it: PVD
http://ttigroup.org.uk/serviceops/gener ... ileid=2358
http://ttigroup.org.uk/serviceops/gener ... ileid=2369
http://www.plasma-plus-pvd.de/cms/Files ... lus_en.pdf
TiALCN /or ALTICN titanium Nitrite coating in old rose colour..(presumably the latter one)
or HE Z (TiCN + TiAlN) your take. it´s tough to extremes.
PVD is a striking process physical vapour deposit you can also put decorative finishes to plastic and make em look like Unobtainium...
aussiegman
aussiegman
105
Re: F1 hub coating
marcush. wrote:my take on it: PVD.....
Looking at the spec sheet, the EXXTRAL Rose looks like the coating used.
800C temp range, high hardness, low friction, high oxidation resistance.
Excellent for stainless steel and nickel based alloys.
300M and EXTRAAL Rose coating is the best guess... +1 for you mate... =D>
Never approach a Bull from the front, a Horse from the back, or an Idiot from any direction
