Sidepod design and the Meredith effect
Cold Fussion
Cold Fussion
93
Re: Sidepod design and the Meredith effect
I was talking about the diffuser before the radiator. I assume it must also have a variable geometry, but I can quite see how it works from that image. Similarly, if we look at the ducting for the BF109 F:
The inlet diffuser in this diagram depicts a separation angle of like 30+ degrees, so I don't see how it doesn't just separate at the entry.
olefud
olefud
79
Cold Fussion wrote:I was talking about the diffuser before the radiator. I assume it must also have a variable geometry, but I can quite see how it works from that image. Similarly, if we look at the ducting for the BF109 F:
http://109lair.hobbyvista.com/techref/s ... irflow.jpg
Radiators tend to function on pressure difference and low speed flow through the radiator – though turbulent radiator flow would be an interesting topic. The divergent inlet slows the flow and increases the pressure more or less in accord with the X-section increasing area of the diagram. Slower flow fills the increasing volume in front of the radiator and pressure difference drives the flow across the radiator. The heated air is then reaccelerated through the converging outlet.
There’s not much to be gained from Meredith at car speeds.
