Yes it did seem to be the case. At least equal second if not second fastest given Sainz is usually over a tenth off Leclerc in race pacePlatinumZealot wrote: β04 Apr 2023, 03:39Does anyone else think that the Ferrari was the second fastest car in race pace? Sainz was really slicing thru the field.
A really strong right leg, and a tricky left?chrisc90 wrote: β03 Apr 2023, 21:33Just been flicking through the telemetry on F1 tempo and has anyone else noticed the odd braking input from Russel on the straights? You can just about pick out any lap thats recorded and there will be a odd section of speed trace and random dabs of 100% brake.
I presume this will just be a glitch, but it looks a bit consistent in the same places each time.
There's also 104% throttle in places.
The man has serious talent. His Lewis I thought was the best. Nailed his voice. Same with George. His eyes and accents were spot on. Really impressive.
It's possible Merc was faster but Lewis only drove as fast as it was needed to keep Alonso out of DRS. Who knows. Ferrari have certainly shown to have better one lap pace in Jeddah and Bahrain. So without degradation, it's quite possible over race distance as well.PlatinumZealot wrote: β04 Apr 2023, 03:39Does anyone else think that the Ferrari was the second fastest car in race pace? Sainz was really slicing thru the field.
The reasons for dismissing it are interesting. They basically say that race control had no time to have a closer look into it, and that's why they went back to the order of the start. Not because the rules require this, but because the "determination needed to be done in the context of a timed race" and "this was in fact done appropriately".F1doc wrote: β02 Apr 2023, 16:44The Haas protest was duly dismissed.
https://www.formula1.com/en/latest/arti ... SJOdd.html
Didn't Alonso post-race imply aston was probably faster in the race to match Hamilton and stay within 1.3.s for most of the race? I'll watch the post-race press conference to confirmpeewon wrote: β04 Apr 2023, 08:24It's possible Merc was faster but Lewis only drove as fast as it was needed to keep Alonso out of DRS. Who knows. Ferrari have certainly shown to have better one lap pace in Jeddah and Bahrain. So without degradation, it's quite possible over race distance as well.PlatinumZealot wrote: β04 Apr 2023, 03:39Does anyone else think that the Ferrari was the second fastest car in race pace? Sainz was really slicing thru the field.
Again it questions if the whole rulebook needs rewriting and simplifying.search wrote: β04 Apr 2023, 08:51The reasons for dismissing it are interesting. They basically say that race control had no time to have a closer look into it, and that's why they went back to the order of the start. Not because the rules require this, but because the "determination needed to be done in the context of a timed race" and "this was in fact done appropriately".F1doc wrote: β02 Apr 2023, 16:44The Haas protest was duly dismissed.
As mentioned, in Bahrain 2020 they used the running order instead - but admittedly, there was a lot of time after Grosjean's crash.
So by the sound of it, they can use whatever order they feel like using next time again.
Not really; With the exception of Max checking out after getting past the Mercedes, all Lewis had to do was maintain the gap to Fernando; Both were conserving for a lot of the race. Yes, Sainz made some progress through the field but took a bit of time to get past Gasly, and even then couldn't pull away... and despite getting a bit closer, he never truly was in the fight with Alonso and Hamilton.PlatinumZealot wrote: β04 Apr 2023, 03:39Does anyone else think that the Ferrari was the second fastest car in race pace? Sainz was really slicing thru the field.
Gasly's tires didn't seemingly decided to let go... He lost DRS and was promptly dropped quite quickly. His car was very understeery in any corner, was evident from Carlos onboard when behind Gasly, he was setup with less downforce which allowed him quite a lot of speed. He would routinely gain half a second in just the back straight into T9-10 with the DRS active, even if Sainz was able to go past 1s before that DRS zone Gasly would be back in DRS range by the next detection point (which was all the way back to the main straight really since the 2 DRS zones in the back had 1 detection point right after T6). Gasly burned his tires to stay close to Sainz, it was a good performance overall and if Ferrari had less downforce in the car he would have left him earlier for sure but probably Carlos tires wouldn't have lasted like they did.Schippke wrote: β04 Apr 2023, 15:45Not really; With the exception of Max checking out after getting past the Mercedes, all Lewis had to do was maintain the gap to Fernando; Both were conserving for a lot of the race. Yes, Sainz made some progress through the field but took a bit of time to get past Gasly, and even then couldn't pull away... and despite getting a bit closer, he never truly was in the fight with Alonso and Hamilton.PlatinumZealot wrote: β04 Apr 2023, 03:39Does anyone else think that the Ferrari was the second fastest car in race pace? Sainz was really slicing thru the field.
It became more evident in the later stages when they both started pushing and started leaving Carlos behind. And Gasly was still keeping pace him to for a while after that right before his tyres seemingly decided to let go...
So whilst it was a better race (pace wise) for Ferrari, I'd argue they're still no stronger than the 3rd-4th best car at the moment... such a fall from grace(?) from the SF-75. The best they can hope for is a recovery to P2; Red Bull would have to literally pull a 2022 Ferrari to loose this years Championship.
I think he had many good laps, some very aggressive passes with young tires and would have finished with the fastest lap without the last 3-4 laps IIRC. However his climb back became progressively harder the more into the top 10 he got and further in the race, it was surprising to see him behind Norris for all those laps when even SAI managed to get past in 1-2 laps at the start. I didn't follow his race too closely but he's probably being told to not churn the tires. The first red flag with everyone on new tires completely ruined the race, in particular it ruined his race as well as RUS and SAI.
