2017-2020 Aerodynamic Regulations Thread
Juzh
161
Re: Proposed 2017 F1 Aerodynamic Changes
Is the neutral section within the front wing staying the same length/dimensions, or is getting proportionally increased relative to the overall wing increase?
henry
324
Juzh wrote:Is the neutral section within the front wing staying the same length/dimensions, or is getting proportionally increased relative to the overall wing increase?
The neutral section is IDENTICAL. That is it doesn't reach forward to the new pointy front. Seems like an error in the regs but we've seen how these sort of errors sometimes have consequences.
Edit: there was some discussion of this earlier in the thread. http://www.f1technical.net/forum/viewto ... ng#p644071
bhall II wrote:
godlameroso wrote:This year the front wing is 800mm...
825mm
http://cdn-8.motorsport.com/images/mgl/ ... t-view.jpg
So 34 mm assuming zero offset, of course most run some positive offset.
FPV GTHO
FPV GTHO
Is it track width or wheel width stated in the regulations? All illustrations indicate 2m will be the outside of the tyres which is what I assumed would be the case. In that case then, right now there is 75mm tyre outside the wing and 170mm inside, next year that will be 100mm outside/205mm inside. They both go up 30mm but proportionally more to the outside.
Regulations state
3.3 Overall width :
The overall width of the car, excluding tyres, must not exceed 2000mm with the steered wheels in the straight ahead position.
Which can only mean the measurement is done at the hub.
232
I think the changes will improve the show. A more physical car to drive will mean that some drivers will perform better than others physically. With later braking, and higher cornering speeds, drivers will deeper limits to explore and this opens up a bigger difference with a good driver and a great driver. We will see more mistakes, and i think more decisive racing.
I stress more decisive and not closer. Close racing is actually boring if there is no tussling, late braking or position changes taking place. I think we should get more balls to the wall stuff next year.
joseff
godlameroso wrote:Regulations state
3.3 Overall width :
I think it means width at wheel rims
3.3 Overall width :
Yes the center of the wheel where it mounts on the hub.
FPV GTHO
FPV GTHO
The hubs poke out almost past the wheels anyway, so it's not going to be the true track width which is centre to centre of the tyres.
470
FPV GTHO wrote:The hubs poke out almost past the wheels anyway, so it's not going to be the true track width which is centre to centre of the tyres.
It is defined as the overall width, not "track width".
And, no, the wheel hubs don't extend past the rims, especially not at the rear.
http://www.gurneyflap.com/Resources/hub.jpg
henry
324
Because they run with positive camber the measurement point will be the lowest point on the wheel rim.
Will explain most things
The first picture shows track width 2m the rest are measuring at the edge of the tire. Which one is right?
FPV GTHO
FPV GTHO
The first one looks to be indicating the floor width but calling it track width.
2009-2013 we had 1.8m front wings and 1.8m suspension width, but the tyres were tucked in behind the wing. I'm confident the overall width will be no more than 2m next year
470
godlameroso wrote:The first picture shows track width 2m the rest are measuring at the edge of the tire. Which one is right?
Neither. Track width is not defined in the regulations.
And the overall width is measured without tyres.
