In a rough surface there are a lot of peaks and valleys. This roughness increments the apparent surface, apparent in the sense that is measured as width times length (the nominal area of the contact patch). But the real area of contact is assumed as a self-fractal with A = L^H, where L is the nominal lateral length and H is the Hurst exponent. This area is proportional to the normal force. I cannot stress enough the importance of the precedent phrase. Until I read this article (and I paid 28 dollars to do it, all well spent), nobody had explained to me why friction forces are proportional to normal forces. But there you have it: the real area of contact varies proportionally to normal force. This variation in contact area is, of course, invisible to the naked eye. http://prola.aps.org/abstract/PRL/v87/i11/e116101
The efective area of contact can be increased: the "bonds" that are supposed to exist do not. But if you could liquify somehow the rubber, you could fill the voids that exists between the fractal surface of the road and the rubber that is envolving it. This is precisely what F1 tyres do: they exude a liquid that simply increases the effective area of contact. Actually, F1 tyres are not worn (well, not until the "one race rule"), they are sucked dry. Finally, you have to take in account that, once you know your real microscopic contact area, all you need to know is how the rubber stores and dissipates energy. Mr. Persson's theory simply states that rubber is elastic until the yield point and plastic beyond it (like they taught you in basic materials), but that in certain modes of vibration and at certain frequencies, the modulus of elasticity can be increased a thousandfold, which is another surprising result. http://scitation.aip.org/getabs/servlet ... s&gifs=yes
You can find a short article resuming Mr. Persson theory here: http://unisci.com/stories/20022/0612023.htm. I have read that the theory is so good that you do not need a whole tire to predict its behaviour. I have heard that the tire makers use it. Please, correct me if I am wrong.
And this is Mr. Persson (hey, I love this guy, I think he is the unknown genius behind Ferrari's dominance from 2001 to 2005, but all you know I am a dreamer):
