Red Bull RB16B
Re: Red Bull RB16B
Alexf1 wrote:
02 Nov 2021, 09:46
Curbstone wrote:
02 Nov 2021, 08:40
A new chassis is not an upgrade. The specs of the new chassis must be the same as the old.
The replacement was done because there may have been something wrong with the old one, not because the new one was better.
Maybe they tested all chassis on flex and changed to the least flexing one(s)
The high rake philosophy may work wonderfully around places like Mexico and Brazil because the high rake promotes strong vorticity.
https://www.f1technical.net/features/23505
This wonderful and incredibly insightful article =D> mentions this in beautiful detailed CFD images.
Perhaps the high rake setup with it's well defined vorticity is somewhat less sensitive to altitude changes for (in my caveman reasoning*) the same reason that turbocharged engines are somewhat less sensitive to altitude changes.
Bandit1216
21
Re: Red Bull RB16B
godlameroso wrote:
02 Nov 2021, 17:09
Alexf1 wrote:
02 Nov 2021, 09:46
Curbstone wrote:
02 Nov 2021, 08:40
https://f1tcdn.net/images/features/2021 ... angled.jpg
I always wondered what the real reason was. A huge compressor, and so less rpm than needed on the compressor-mgu-h-turbine assembly, having more spare to increases rpm on altitude. I thought Renault and later Honda were more on the large side, accepting a little bit more lag (or more energy to compensate for lag), and merc being more on the limit, so they do not have rpm spare for altitude. Pikes peak engineers know all about this. The rpm on the turbo will increase significantly when the turbo is compensating for high altitude.
But the rake is beyond me. The turbo is quite simple a waste gate that compensates, but the chassis?
If you see the pictures of that article one could imagine why a merc is especially limited when trying to pass a redbull.
Re: Red Bull RB16B
Bandit1216 wrote:
02 Nov 2021, 17:22
godlameroso wrote:
02 Nov 2021, 17:09
Alexf1 wrote:
02 Nov 2021, 09:46
A compressor's inlet creates a vacuum, a suction at the throat, a compressor does in practice what the name ram air did in advertising.
The low pressure conduit at the throat of the compressor draws in air. The low pressure in a vortex acts as a conduit for air, and the effect is enhanced due to, well, ground effect. Because there's less atmospheric pressure, the core of the vortex being a conduit becomes more efficient, somewhat negating the reduction in overall mass flow. For the same reason the conduit in the compressor inlet negates the reduction in overall mass flow.
Alexf1
Alexf1
Re: Red Bull RB16B
godlameroso wrote:
02 Nov 2021, 17:09
Alexf1 wrote:
02 Nov 2021, 09:46
Curbstone wrote:
02 Nov 2021, 08:40
Indeed, if an F1 boss shouts to all look left (our engine works miracles on altitude) you know you have to look right (its the aero they don't want you to take a look at). Wasn't it a coincidence that in a RB not only the Renault engine did well on altitude but also the Honda..?
Re: Red Bull RB16B
godlameroso wrote:
02 Nov 2021, 18:03
Bandit1216 wrote:
02 Nov 2021, 17:22
godlameroso wrote:
02 Nov 2021, 17:09
Maybe it worse cause low rake has 2 vortexs closer together that help push each other?
Anyways both Merc and RBR are running high rake.
That article avoided talking about the being able to run a 2 degrees lower rear wing angle(with High rake) and getting the same rear wing angle(at lower speeds)of a low rake car.
Also was RBR having the FIA check Merc rear suspension...Is that confirmation that they think Merc is using a 3 stage high rake ? Where at extreme high speed they feel the Merc is getting so low in the rear of the car that they're stalling the diffuser resulting in less DF and drag?
hollus
Re: Red Bull RB16B
Wrong thread... You are more than welcome to link to a rake thread, or create one, and continue there. But here, please, RB16 or nothing.
Rivals, not enemies.
Bandit1216
21
Re: Red Bull RB16B
hollus wrote:
02 Nov 2021, 21:01
Hmmmmm. May I please have a bit reservation on that, or will that get me banned? Can one talk about Alexandra Daddario and whether She is beautiful or not, without discussing her (imo) very beautiful breaths? It's kinda a package deal isn't it? Alexandra is definitely off topic. I can agree in that :D
Re: Red Bull RB16B
Red Bull: several brake sockets for thin air
Giorgio Piola
Nov 5, 2021, 10:13 am
The Milton Keynes team introduced an enhanced brake cooling system in Mexico City to provide the disc and pads with the necessary fresh air despite a flow with a density much less than sea level.
More pictures of the RB16B in Mexico. Just click on the arrows in the images to scroll through them…
https://www.motorsport.com/f1/news/f1-m ... s/6747934/
Re: Red Bull RB16B
Via Motorsport.com
dxpetrov
dxpetrov
-7
Re: Red Bull RB16B
Monaco style rear wing, as expected...
etusch
131
Re: Red Bull RB16B
Morteza wrote:
05 Nov 2021, 15:50
Metal teeths at older became CF.
SuperCNJ
SuperCNJ
Re: Red Bull RB16B
Any clues as to whether there could be upgrades for the last two races or is it too late for that now?
Re: Red Bull RB16B
Can anyone tell me where I can find the race scrutineering of the last race?
I'm curious about car 33 and car 11. The last pdf I can find is this one:
https://www.fia.com/sites/default/files ... eering.pdf
west52keep64
51
Re: Red Bull RB16B
25 Nov 2021, 22:14
It's here:
Re: Red Bull RB16B
west52keep64 wrote:
26 Nov 2021, 00:32
25 Nov 2021, 22:14
It's here:
Thank you @west52keep64.
This ( Event&Timing Information) is the site I always use during the raceweekends when I go to the FIA site
and there is no doc 53 at the Technical Reports,
normaly there is always the race scrutineering, this time it isn't. :
https://www.fia.com/events/fia-formula- ... nformation
