McLaren MCL60
the EDGE
the EDGE
67
Re: McLaren MCL60
26 Oct 2023, 20:06
Why are the measuring the flow going under the wing? Surly that wouldn’t tell them anything about the performance of the wing it’s self? I would have thought It would be used to check something further up wind of the sensor?
Re: McLaren MCL60
the EDGE wrote:
26 Oct 2023, 23:42
26 Oct 2023, 20:06
Correlation to windtunnel and CFD in the same locations.
ANDY238
ANDY238
Re: McLaren MCL60
maygun
maygun
Re: McLaren MCL60
the EDGE wrote:
26 Oct 2023, 23:42
26 Oct 2023, 20:06
Probably to check about the flow that interacts with the flow that comes from the diffuser?
Farnborough
Farnborough
91
Re: McLaren MCL60
The speed going under the wing, relative to top surface, is what makes a "downfirce" for an inverted wing profile such as these car.
The greater the difference between the two (put crudely) the more the wing exerts direct load.
Goblin42
57
Re: McLaren MCL60
CjC
CjC
Re: McLaren MCL60
Goblin42 wrote:
27 Oct 2023, 16:13
Yet the others are looking to add the kicks….?
Just a fan's point of view
Re: McLaren MCL60
That doesn't look like a max downforce beam wing for Mexico.
LionsHeart
LionsHeart
Re: McLaren MCL60
the EDGE wrote:
26 Oct 2023, 23:42
26 Oct 2023, 20:06
Flow under the wing is the most important thing in the field of aerodynamics. It is generally considered normal to pay critical attention to the longer side of the wing. On the longer side the flows are faster, which increases the rarefaction in this area, but also increases the risk of airflow stall. This is the principle on which the airplane wing works. :)
Re: McLaren MCL60
Goblin42 wrote:
27 Oct 2023, 16:13
Equally interesting they have moved away from a round diffuser roof to a more squarer one. In 2022 it was thought the round roof was allowind redbull better downforce. Mclaren is showing here that it is not all about the number of kicks and a roun roof! It's more upstream that the performance lies.
☄️ Myth of the five suns. ☄️
LxVxFxHxN
Farnborough
Farnborough
91
Re: McLaren MCL60
CjC wrote:
27 Oct 2023, 17:38
Goblin42 wrote:
27 Oct 2023, 16:13
The RB floor is similar in having less steps currently, I believe.
trinidefender
trinidefender
317
Re: McLaren MCL60
PlatinumZealot wrote:
27 Oct 2023, 18:37
Goblin42 wrote:
27 Oct 2023, 16:13
The opposite. They've gone from a square roof on the diffuser corners to rounded ones in the Austria update.
Re: McLaren MCL60
Chwkc the Mexico photos. The roof is more squared off.
LxVxFxHxN
mwillems
Re: McLaren MCL60
Does anyone have pics of the beam wing config used at COTA?
No matter, FIA docs show nothing has changed.
-Bandit
Re: McLaren MCL60
Soymotor.com 📸
