Most pec...bizarre aerodynamics thread.
Re: Most pec...bizarre aerodynamics thread.
So it does just act to counter oversteer using the downforce to "pull" the rear inwards.
roon
roon
412
The bizarre aero isn't even the car on itself; This car ran negative rake to cut drag at Le Mans
Holm86
245
Just_a_fan wrote:
17 Jul 2018, 23:45
By that mantra, ALL downforce is there just to counter either over or understeer??
It seems rather silly really, trying to counter the yaw directly with the wing, when if you're on track tyres and racing slicks your friction levels are going to be >1.0 between the tyre and road anyway, so the downforce would be better acting directly on the tyres, you'd get more grip that way, and you don't have to compromise the wing for all the odd AoA's and transitions it's got to deal and cope with.
Just_a_fan wrote:
17 Jul 2018, 23:45
It counteracts centrifugal force first, over/understeer second. If you have another active force giving the car radial acceleration (besides steering), you can go faster trough a corner since you can increase centrifugal force that one bit.
#Aerogimli
roon
roon
412
Flying JPS Lotus
37
Koenigsegg One:1 rear wing
"Looks like meat's back on the menu boys!"
#AeroUruk-Hai
gixxer_drew
gixxer_drew
29
wesley123 wrote:
18 Jul 2018, 11:12
http://www.all-free-photos.com/images/l ... 108-hr.jpg
That is interesting.
The first little bit of a wing is converging to ground plane. But a total effect can be desirable.
Many reasons could exist for this, and I have seen it done before. I am curious though was it at a negative rake when static? Or settling under aero load?
djos
113
wesley123 wrote:
18 Jul 2018, 11:12
Williams did that with their active suspension in the 90's, they had it as a push to pass button on the steering wheel. Basically an early form of DRS.
"In downforce we trust"
gixxer_drew wrote:
16 Sep 2018, 10:42
wesley123 wrote:
18 Jul 2018, 11:12
Those cars had front diffusers so they could get away with a lot of things.
gixxer_drew wrote:
16 Sep 2018, 10:42
wesley123 wrote:
18 Jul 2018, 11:12
I'm not sure if it was negative rake static or only under load.
The issue that Audi had was that they designed a car more suited for IMSA. However, for Le Mans they found it very difficult to shed enough drag. Apparently the through the car aero gave it lots of downforce, but made it difficult to shed the drag they required. Thus, negative rake was applied
roon
roon
412
NathanE
NathanE
If that's supposed to produce downforce it's not working very well :D
I like the big Aircon unit mounted on the roof.
djos
113
NathanE wrote:
06 Jul 2019, 08:09
That's not a wing, it's an air brake!
