Most pec...bizarre aerodynamics thread.
vorticism
323
Re: Most pec...bizarre aerodynamics thread.
Vanja #66 wrote:
26 Jun 2023, 12:29
Aircraft would be capable of recovering gravitational potential energy when descending, but this isn't available to road vehicles.
Ultimately for traction vehicles using the wheels for regen is the most effective. If some cars were propeller/fan impelled than it could be a different case.
𓄀
vorticism wrote:
26 Jun 2023, 16:35
https://i.ytimg.com/vi/qmZtOm3Qb4A/hqdefault.jpg
I knew someone was gonna mention this :mrgreen:
Aircraft are flying quite high for lower air density, which in turn reduces drag and fuel burn. So when they are descending, they start from up to 10km and with large and heavy aircraft that's a lot of potential energy. :)
Road vehicles can have what, up to 100m of descent in total on a typical commute? That's not really enough to install a small wind turbine, when you already have wheel regen :)
#Aerogimli
Vanja #66 wrote:
27 Jun 2023, 10:00
vorticism wrote:
26 Jun 2023, 16:35
Energy management is almost the biggest part of planning and executing the descent / approach profile. Approaches (top of descent) will often start somewhere around 100miles from the airport. There's a lot of energy to get rid of in those few miles.
Billzilla
Billzilla
Just_a_fan wrote:
27 Jun 2023, 22:21
Vanja #66 wrote:
27 Jun 2023, 10:00
vorticism wrote:
26 Jun 2023, 16:35
Can confirm. A heavy aircraft is harder to get down than a light one. Well, airliners at least.
vorticism
323
𓄀
vorticism
323
vorticism wrote:
24 Jun 2023, 18:34
𓄀
Big Tea
99
Saw an old Porsche in town this morning with a big steel plate 'wing' on the back must weigh 40 lb. No profile, just a plate 5ft bu 1ft bolted to a strut. Probably does wheelies.
vorticism
323
Big Tea wrote:
06 Jul 2023, 12:04
More for traction in loose soil.
𓄀
Vanja #66 wrote:
26 Jun 2023, 12:29
Aircraft would be capable of recovering gravitational potential energy when descending, but this isn't available to road vehicles. :)
How would the aircraft store that energy? Batteries? With the weight, you probably don't come out ahead.
Also I suspect this method would require a descent rate would cause people to lose their stomach contents... :)
scuderiabrandon
81
Image Image Image Image
Scribante Racing GT-R. Aero package designed by Dr. Sammy Diasinos, (DAS) Dynamic Aero Solutions. It lacked front downforce and the short term solution was to adapt a modified rear wing on the front. It sorta bacame a trademark and I believe it still runs it today.
djos
113
scuderiabrandon wrote:
07 Jul 2023, 01:46
https://ibb.co/9Zx7V1Y https://ibb.co/V3bz1bv https://ibb.co/X4VDXJz https://ibb.co/NpsnyN2
That car is pretty wild and a lot of fun to watch! Here’s a great video on it that I saw recently.
"In downforce we trust"
vorticism
323
☝🏻 Works for F1 going on fifty years.
Next up, the classic inlet endplate (scoop stay? pillar duct?):
𓄀
The BMW M1C
Massive diffuser tunnels:
Image.
Giblet
Giblet
13 Jul 2023, 18:25
What are the snorkels feeding?
Air intakes for the turbos out in the air to assist cooling the charge air, or just no more room underneath.
