vorticism
323
Re: Mercedes Power Unit Hardware & Software
Note the road car spec oil filter and headers. Everything else looks identical.
๐“„€
vorticism wrote: โ†‘
17 Aug 2022, 23:19
https://i.imgur.com/BCHZzZG.jpg
What makes you say it's a road car spec oil filter and headers? Other than the "easy out" design, I would imagine the filter here has fewer pleats and a lower resistance than the road car.
vorticism
323
That's all, just the location and size are unique. The headers are wider, not held close to the block. This is the road car version btw, not sure if you saw the prev post.
๐“„€
It would make a great marketing segment if they could share something like the oil filters though :o
17 Aug 2022, 00:30
From the AMG One. Nice to finally see more details of these engines after eight years.
https://i.imgur.com/9npSSy6.jpg
It's a casted version. Interesting.
saviour stivala
saviour stivala
AMG ONE block. Sand printed mold casting pour filled from bottom up most probably cast in Germany and supplied for build to Brixworth. The AMG ONE uses both direct and induction injection.
etusch
131
The 2026 Engine Changes Explained! | F1 TV Tech Talk
227
So turbo lag will factor into the car's charactrristics in 2026 and driving style.
500hp kers... will the ice still have up to 750hp?
will fuel pressure increase.
ringo wrote: โ†‘
21 Aug 2022, 19:49
Pretty sure the document from the decision made by the FIA states that the new ICE target is around 540 HP - a 40% decrease on existing ICE regs
ringo wrote: โ†‘
21 Aug 2022, 19:49
I think both the fuel capacity and fuel flow rate have been slashed. From there you can work out that there will have to be a horsepower reduction unless somebody invents a new combustion cycle :P
227
Oh okay. I didnt notice they cut that down. :wtf:
Some great images in this thread
Couple of examples:
chrisc90
37
What advantage do the vanes serve?
saviour stivala
saviour stivala
Those moveable vanes in front of compressor intake. A throttling system. Manipulating that throttling system will result in less turbo lag, faster turbo spinning, no need for a blow-off valve.
