Red Bull RB12 TAG-Heuer
ME4ME
79
Re: Red Bull RB12 TAG-Heuer
henra
henra
Re: Red Bull RB12 TAG-Heuer Speculation Thread
Wow!
That gives a whole new meaning to 'Size Zero'.
Here's seriously impressed by the level of compression. That's when I thought the SF-16 looked sleek at the back.
RB11 was already very thin at the back... RB12 is a bit more thin
Owen.C93
Owen.C93
172
Perfect tear drop ;)
228
Ferraripilot wrote:I thought their batwing looked quite different. Thanks for the post. Is its purpose to bisect flow around the sidepods or to aid in flow attachment, or both?
I would suspect lift reduction on the underside of the tub (more net down-force), and also it may improve efficiency of the floor downstream of it.
f1316
f1316
79
henra wrote:
Wow!
But you have to appreciate that the Ferrari follows that exact same shape at the back, underneath the upper bodywork where they *choose* to have it flare outward.
This is likely to guide airflow, but regardless: if they wanted the bodywork to do the same as the RB, it seems likely they would have just kept it the same as the bottom part.
djos
113
Blackout wrote:RB11 was already very thin at the back... RB12 is a bit more thin
http://i84.servimg.com/u/f84/14/79/55/26/f1-bar11.jpg
Incredible how the headrest now wraps around Dan's helmet too, it's like the car was shrink wrapped around him!
"In downforce we trust"
Even from this angle you can tell how much rake the car is running.
gandharva
252
Imho the new splitter vane could help to reduce downforce at higher speeds by lifting the T-Tray.
https://twitter.com/ScarbsF1/status/702048674273214464
proteus
22
Cameras or sensors mounted in the mirrors?
Mr.G
34
Infra cameras for tires...
LookBackTime
LookBackTime
472
Gridlock
30
I wonder why they've 'spent the weight' to put those straps between the exhausts. No other team did this, right?
Looks like titanium, so I guess it's probably only 12g...
#58
djos
113
Gridlock wrote:I wonder why they've 'spent the weight' to put those straps between the exhausts. No other team did this, right?
http://i.imgur.com/BgWEqoi.jpg
Looks like they'd cut down unwanted vibrations from having then so close to the main exhaust.
Edit they aren't straps, they are welded supports I think.
Gridlock
30
Yeah 'straps' was shorthand for a beautiful piece of bracket :)
All the teams have them in close proximity though, just found it curious. It's quite high to be adding weight, in the obsessive world of F1.
#58
