WEC 2020 Tech Regulations - Hypercar Regulations
ENGINE TUNER
ENGINE TUNER
25
Re: WEC 2020 Tech Regulations - Hypercar Regulations
roon wrote:
16 Jun 2019, 20:26
Singular fuel supplier--something F1 should try.
Disagree, keep all the different fuel suppliers in F1, require 100% biofuel from nonfood sources. I want ocean algae that eats ocean plastic and makes biofuel for my cars simultaneously.
So are the aero limits still a thing?
jjn9128
770
wesley123 wrote:
18 Jun 2019, 11:12
Waiting for actual publication of the regs. But I'd think that is set on stone. Common sense ruling for me. With bop if everyone maxes the aero limits then at least that's actually equal and not a part of some performance matrix.
#aerogandalf
roon
roon
412
Holm86 wrote:
02 Sep 2019, 12:34
Impressive achievement, and a long tail Chiron looks pretty good.
Ready for Le Mans hypercar class from 2021?? :D [-o<
That would be interesting to see, but the large engine may be at a disadvantage. The power output is supposed to be limited to 750 hp, approximatrly half of the Chiron engine output.
roon wrote:
03 Sep 2019, 17:51
Holm86 wrote:
02 Sep 2019, 12:34
But the Chiron makes 750bhp at about mid revs - whilst everything else is still getting in to their stride. The Chiron would be getting 750bhp at 4000rpm and then staying there. They'd have to map it to reduce the torque from that rev mark in order to keep the power steady at the maximum allowed. Assuming it's not traction limited - and being 4wd it isn't - it'll be f'ing quick out of the corners! It's an interesting thought, the Chiron racing. =D>
Maritimer
Maritimer
19
AWD is only allowed once the vehicle passes 120kph though
120kmh isn't that fast really, I'd expect many corners will be 4wd-able in the dry, at least.
Maritimer
Maritimer
19
No doubt, but the Chirron is full-time AWD, so they would need a completely new drivetrain on top of tuning the engine to run like a diesel if they ever wanted to take a stab with it.
Jolle
Jolle
Building a racer out of a (hyper) road car always takes an almost full redesign. This in not just slapping on a few numbers and weld in a roll cage.
Glickenhaus have unveiled this, the SCG 007, as their entry. No technical details yet
Maritimer
Maritimer
19
TS020 meets XJ220
Jolle wrote:
04 Sep 2019, 10:53
Except the F1, of course, which had a some aero bits changed (the fan powered diffuser and the active rear spolier removed, a front splitter added) and a roll cage added but nothing else really. Won Le Mans on its debut.
But the F1 was special and thus your point basically stands as correct.
Maritimer wrote:
20 Sep 2019, 02:12
TS020 meets XJ220
But with the nicest bits of both left out. It's not a looker, that thing.
