lh13
lh13
Re: 2022 Aerodynamic Regulations Thread
f1jcw wrote:
Zynerji wrote:
12 Jun 2022, 19:08
mzso wrote:
12 Jun 2022, 19:02
So since at any given time half the field fails to do so, we should accept that drivers miss races due to injuries, or might even retire, instead of implementing something that completely prevents the problem?
The teams can solve it immediately by raising the rear ride height, and giving up performance.
The drivers only suffer because the teams choose it for laptimes.
So, you want a unlevel playing field.
Teams couldn’t compete with mercs frick, party modes, etc. they was removed, often in season
Multiple teams have solved the problem. McLaren are even giving up some performance to manage the situation, according to Norris, and they're happy with it. Its not a single team that has found a grey area to fix it. Mercedes has got it worst, so effectively their own problem, not regulations'.
622
mzso wrote:
12 Jun 2022, 19:02
JordanMugen wrote:
12 Jun 2022, 18:47
As Symonds says, the inerters are not necessary, the phenomenon is "fixable within the framework of the rules and the technology allowed on the cars now". The secret, as he says, is "to minimise the oscillation": i.e., like the Red Bull does, which can be done within the existing suspension regulations.
why complain about 6g (momentarily) in bump ? - the cars are made for almost 6g continuously in braking & cornering
Zynerji
109
mzso wrote:
12 Jun 2022, 19:13
Zynerji wrote:
12 Jun 2022, 19:08
But they will never do that as long as it requires giving up performance.
Then it's not my problem, or anyone else's.
Cannot and will not are not the same thing.
Zynerji
109
f1jcw wrote:
12 Jun 2022, 19:30
Zynerji wrote:
12 Jun 2022, 19:08
mzso wrote:
12 Jun 2022, 19:02
Maybe if your team could reach other teams' level, it would be fine?🤔
InsaneX_Badger
To anyone who understands these aero concepts better than I ever could. Is there a concept that will work much better at higher altitudes with air density being lower? Or will it just reduce each car equally?
lh13 wrote:
12 Jun 2022, 19:47
f1jcw wrote:
Zynerji wrote:
12 Jun 2022, 19:08
At least two teams are alleged to have solved it using a potentially illegal method. We'll have to see what comes of the floor rules "clarification" in the next week or two.
In Silverstone, at least, the Merc was certainly not being adversely affected - Hamilton was setting fastest lap after fastest lap at one point.
Zynerji wrote:
12 Jun 2022, 21:33
f1jcw wrote:
12 Jun 2022, 19:30
Zynerji wrote:
12 Jun 2022, 19:08
Same could be said (and was by some) in previous years when Red Bull were crying foul at every race because their PU wasn't as good as the competition's. In the end, they got the rules changed to their benefit. :wink:
chrisc90
37
Just_a_fan wrote:
03 Jul 2022, 19:18
lh13 wrote:
12 Jun 2022, 19:47
f1jcw wrote: So, you want a unlevel playing field.
I dont think the 'flexi floor' saga is a solution for the bouncing. There is still no confirmed stories that any team is using any 'illegal' floors, purely speculation because a few teams were not happy with discussions in a meeting. Mainly Ferrari and RB, but it was the same pre-TD when they both called for no change.
Ill be massively surprised if there is anything to come of this come Paul Ricard.
Stu
Just_a_fan wrote:
03 Jul 2022, 19:19
Zynerji wrote:
12 Jun 2022, 21:33
f1jcw wrote:
12 Jun 2022, 19:30
Are you talking about the floor cuts last year? I recall that pressure came from Pirelli because the teams didn’t want the tyres to be altered from 2019 (because they didn’t like them).
Stu wrote:
03 Jul 2022, 19:23
Just_a_fan wrote:
03 Jul 2022, 19:19
Zynerji wrote:
12 Jun 2022, 21:33
No, the killing of the qualifying modes mid season was the first thing that came to mind.
Stu
Just_a_fan wrote:
03 Jul 2022, 19:24
Stu wrote:
03 Jul 2022, 19:23
Just_a_fan wrote:
03 Jul 2022, 19:19
That backfired really, didn’t it? The Mercedes PU was simply stronger (and/or their electrical systems were better?), probably a combination of both.
chrisc90 wrote:
03 Jul 2022, 19:22
Just_a_fan wrote:
03 Jul 2022, 19:18
lh13 wrote:
12 Jun 2022, 19:47
I said "alleged" and "potentially" for a very good reason - there is no direct "he's been naughty" from anyone as yet. 8)
It will be interesting to see if any changes happen. Also if said changes bring a change in the pecking order. Any clever interpretations might only be worth a tenth or even just a half a tenth. Or they might be worth half a second. So we might never know or we might say "wow, they've been screwed by the new rules, they must have been naughty before".
Stu wrote:
03 Jul 2022, 19:27
Just_a_fan wrote:
03 Jul 2022, 19:24
Stu wrote:
03 Jul 2022, 19:23
It certainly helped Red Bull in general in qualifying.
JordanMugen
82
The current regulations stipulate a maximum deflection of 2mm at the two middle plank holes and no more than 2mm at its rearmost hole in a bid to ensure that the floor is stiff enough.
However, there were claims some teams have managed to cleverly flex the floors by as much as 6mm in total, which would allow them to run with higher rake and much closer to the ground for increased performance without the risk of suffering the ill effects of ground strikes.
Tombazis made clear that the FIA believed teams having 'excessive deformation' of the floor was being done: "to achieve significantly lower ride heights, and hence an indirect aerodynamic gain."
The 2mm tolerance will be rigorously enforced and the stiffness around the floor hole must now be uniform for a radial distance of 15mm outside the periphery – with a variance not exceeding 10 percent either way.
The FIA added: "Competitors will be required to demonstrate compliance with these provisions by way of a detailed inspection of both the CAD and the physical installation, as well as Finite Element analysis."
https://www.motorsport.com/f1/news/f1-f ... /10332153/
What's all this about? :?:
Any truth to the rumours that the big springs, found on most of the cars, will also be banned? :?:
taperoo2k
taperoo2k
JordanMugen wrote:
04 Jul 2022, 05:51
Same thing it's always about in F1, teams bending the rules to gain a performance advantage, while it takes the FIA a while to cotton onto it. The assumption will be that Red Bull and maybe Ferrari have been doing this. But we'll find out soon enough if teams lose performance at the French Grand Prix. How much performance ? Hard to say at this stage, it could cost a couple of tenths or it could be bigger.
Not heard anything about that, but it wouldn't surprise me if the FIA do decide to ban that. Though I guess the teams might argue they are needed to smooth out the bumps to protect drivers long term health.
