C8 Corvette
Jolle
Jolle
Re: C8 Corvette
roon wrote:
20 Jul 2019, 20:23
Jolle wrote:
20 Jul 2019, 20:01
...the LT2 is quite high compared to what the other sports cars use. A LS2 is almost 80cm high while a modern v8 from a European constructor is below 70cm.
Are you factoring in dry sump?
Isn't the base C7 using wet sump? Defies the "we use it for a low CoG" a bit :P Also, a lot of hight comes from the air intake. There is lots of room between the heads and top of the engine, more then enough to stick a few cam shafts in and have proper breathing (and you'll would be needing a 6.2l engine to have 500ps, 4.5 should be enough) But again, this would add several thousands of dollars to the base price.
roon
roon
412
Re: C8 Corvette
Jolle wrote:
20 Jul 2019, 20:35
Thread is about the C8. The C8 LT2 engine is dry sumped according to Chevy's press release and presentation.
For the first time ever, the base Stingray will use an engine-mounted dry sump oil system and three scavenge pumps for improved track performance.
Note the reduced height of the oil pan. Crankshaft centerline is below the rear axle.
Jolle
Jolle
Re: C8 Corvette
roon wrote:
20 Jul 2019, 20:43
Jolle wrote:
20 Jul 2019, 20:35
https://www.slashgear.com/wp-content/up ... 80x640.jpg
Aha, a bit of progress, together with coil springs :P
But still, there is no other advantage over a modern v8 like the Ricardo or Mercedes 4.0's other than cost. They are as light and as compact as this engine. Plus they are more fuel efficient what limits the guzzler tax.
So with a Corvette, you pay more tax :P
roon
roon
412
Re: C8 Corvette
Jolle wrote:
20 Jul 2019, 20:52
roon wrote:
20 Jul 2019, 20:43
Jolle wrote:
20 Jul 2019, 20:35
CoG will likely be superior even if total engine height is similar, for the reasons given. I doubt a 4L TT DOHC V8 will be as light as an 6.2L NA OHV V8. They may still export a turbocharged model. The LTA Blackwing TT V8 is manufactured in the same plant as the C8. There is a cold-vee TT powerplant in the works as well which GM supposedly confirmed was depicted in the image below.
roon wrote:
20 Jul 2019, 03:55
Maritimer
Maritimer
19
Re: C8 Corvette
The engine in the C8.R isnt an LT2, that render is likely the race engine thatll be retuned for future Z06/ZR1 packages.
strad
117
Re: C8 Corvette
Jolle That dinosaur won at Le Mans (beating Ferrari's) a couple of times that I can remember off the top of my head along with the 24 hrs of Daytona. :wink:
Sir Stirling Moss
roon
roon
412
Re: C8 Corvette
Makes me wonder. Given the height, mass center advantages, would we see pushrods in F1 given the chance. Can still pull off 4v/cyl, much to the chagrin of our resident Europeans. 12k rpm? Feasible. Air springs? Applicable. Common camshaft? Doable. Given nothing fancy is being done with valve timing and duration due to the regs. 1.6L block. Small valves, tiny pushrods.
Weight of nine(?) timing gears+four camshafts vs twelve pushsticks+twelve forked rockers+one camshaft+two timing gears.
Cold Fussion
Cold Fussion
93
Re: C8 Corvette
strad wrote:
21 Jul 2019, 04:27
Anything can win the GT class with the right balance of performance.
622
Re: C8 Corvette
Detroit pushrod design gives canted valves
(invented by accident)
kept it going the last 50 years
got the small block doing the work of a big block
Jolle
Jolle
Re: C8 Corvette
roon wrote:
21 Jul 2019, 05:36
No, not a chance.
Look, I see why you guys love the corvette. It looks like a proper sports car and drives like you own the world. And that for a good bang for the buck. But that buck had to be saved in multiple places. The frame is steel instead of aluminium, the body plastic instead of carbon, etc etc. The engine is dirt cheap.
There was a Dutch football player who had an interesting saying: every disadvantage has its advantage.
If a pushrod engine made any sense in a car, or a sports car, there would be others. In Europe at least, the last pushrod in production was the Rover V8 that was based on an American block, it finally was fased out in the early nineties. Every car, from dirt cheap, high tech, from tractor to F1 car ditched pushrod engines. Even Chevy.
So, everybody including GM got it wrong and the LT2 engineers came up with this amazing tech that will change how we look at engines (again) or its just perfect to push it in a certain price point.
“But it won Indy with Mercedes”. Yeah... because they could use a larger capacity.
Maritimer
Maritimer
19
Re: C8 Corvette
Pushrods would absolutely work in these motors, overhead cams are only better if you need variable lift/timing or crazy high revs. That's really it. Pushrods can go over 12k with good springs and rods, have outstanding valve lift and major packaging advantages. The heads on the current engines are the same size as the block, you could make a pushrod hemi that would be smaller and flow just as well.
e36jon
e36jon
66
Re: C8 Corvette
Greetings all
I have my own biases as I currently drive an e36 BMW with dual overhead cams and 4V per cylinder. That said, the most popular engine swap for my car is a small block Chevy, which is lighter, makes a ton more everything, etc...
Here's a really great technical article comparing F1 V8's to NASCAR V8's: http://www.epi-eng.com/piston_engine_te ... _to_f1.htm
I would also point folks at various C7 motor articles looking at the titanium rods and valves of the last mill. Very very trick, and capable of 8k rpm! (My BMW redlines at 6,500 rpm!)
Cheers,
Jon
roon
roon
412
Re: C8 Corvette
Jolle wrote:
21 Jul 2019, 10:22
I actually don't care much for it. The arguments in this thread seem to defy physics. Thats why I'm responding to them. As is common in this forum, correction is misconstrued as opposition.
Jolle wrote:
21 Jul 2019, 10:22
The chassis is aluminum. The bodypanels are FRP like most modern automobiles bumpers. The rear crash structure is CF.
Jolle wrote:
21 Jul 2019, 10:22
If a pushrod engine made any sense in a car, or a sports car, there would be others. Every car, from dirt cheap, high tech, from tractor to F1 car ditched pushrod engines. Even Chevy.
Camaro still uses one, as do 100s of 1000s of trucks, if not millions. Ford unveiled a new 7.3L pushrod V8 earlier this year.
strad
117
Re: C8 Corvette
Thanks Roon you beat me to it.
Sir Stirling Moss
Tim.Wright
330
Re: C8 Corvette
roon wrote:
21 Jul 2019, 19:52
Jolle wrote:
21 Jul 2019, 10:22
Looks like an aluminium spaceframe with cast engine and suspension mountings. Similar to what Ferrari are doing.
