2020 British Grand Prix - Silverstone, 31-02 July / August
Re: 2020 British Grand Prix - Silverstone, 31-02 July / August
The side wall had waves in them for all the failures.
☄️ Myth of the five suns. ☄️
LxVxFxHxN
ENGINE TUNER
ENGINE TUNER
25
PlatinumZealot wrote:
04 Aug 2020, 00:06
Yes, I saw that as well, clear proof that it is a failure of the tire, not cuts die to debris. Pirelli have always been weak where the sidewall connects to the tread.
ENGINE TUNER
ENGINE TUNER
25
dans79 wrote:
03 Aug 2020, 23:59
RZS10 wrote:
03 Aug 2020, 22:45
There's footage from the rear facing camera ... clearly tyre failure
https://streamable.com/pvsn5e
Pirelli is going to have a lot of explaining to do when the teams and the press core all see this footage. Instantaneous tire failure on a high speed section of track.
They will just lie and say it was debris like they have been doing since 2011.
dans79 wrote:
03 Aug 2020, 23:59
RZS10 wrote:
03 Aug 2020, 22:45
Well, there's also this:
Which suggests that there could have been FOD damage to the tyre. That debris is a long way from the point where the tyre failed. There's got to be question about whether it was an inherent failure or an external-cause failure.
Mogster
Apparently there were less marshals at Silverstone than normal, the justification being the lack of spectators. Dealing with incidents seemed to take much longer than normal, that raises the question of the FOD check not being done as diligently as usual.
ENGINE TUNER
ENGINE TUNER
25
Just_a_fan wrote:
04 Aug 2020, 00:21
dans79 wrote:
03 Aug 2020, 23:59
RZS10 wrote:
03 Aug 2020, 22:45
There was a full complement of support races this weekend, F3, F2 and Porsche supercup. No other series had any tire failures. It is NOT the curbs or debris, IT IS THE GARBAGE PIRELLI TIRES.
All three tires failed on the front left on the inside shoulder where the sidewall connects to the tread. This was clearly a failure of the pirelli construction, nothing to do with debris.
16
Pirelli’s conclude their investigation: https://www.pitpass.com/67554/Pirelli-c ... e-failures
Racer X
Ferrari is proof that in 2020 midfield teams can break into a podium finish, with a little bit of luck.
RedBull Racing Checo//PEREZ
piast9
piast9
214270 wrote:
04 Aug 2020, 15:50
It seems that they've ignored the Kvyat's right rear tyre failure.
dans79
267
piast9 wrote:
04 Aug 2020, 18:22
214270 wrote:
04 Aug 2020, 15:50
197 104 103 7
nevill3
16
Sky F1 are reporting that Lewis managed to maintain a blistering pace on his three wheels
"No front left tyre on the car and he still took Copse and Stowe corners at more than 130km/h," wrote Brawn in his post-race column. "He reached 230km/h on the straight with only three wheels, and a front left tyre flailing around - absolutely mind-blowing.
228
Looks like Lewis adapted his driving style to the balance of the 3 wheels.
SiLo
135
ringo wrote:
04 Aug 2020, 20:29
Looks like he went slower for right hand turns and then much faster in the left hand turns knowing the load was on the other tyre.
Felipe Baby!
Wynters
Wynters
Hamilton's tyre blew at turn 7 (?), Bottas' at the end of the lap. Turn 7 is just at the start of sector 2.
Does anyone have Hamilton's sector 2 vs Bottas's sector 2? (sector 3 will be spoiled by Bottas entering the pits).
Also:-
"The Stewards reviewed video evidence and determined that Albon was predominantly at fault for the collision at Turn 18. Passes at Turn 18 are unusual and difficult to execute. While Albon appeared to be the faster car the Stewards determined that he attempted the pass too late and the gap on the inside of Car 20 was always going to diminish. It appeared that he attempted to back out of the pass at the last second. The Stewards took into account that Magnussen had a slower exit from Turn 17."
Shrieker
-Atatürk
