2021 Italian Grand Prix - Monza, Sep 10 - 12
Re: 2021 Italian Grand Prix - Monza, Sep 10 - 12
Zynerji wrote:
24 Sep 2021, 15:41
Just_a_fan wrote:
24 Sep 2021, 09:02
flmkane wrote:
24 Sep 2021, 06:33
Thats not right. More drag = less top speed for a given power output. More power = more top speed at given drag.
Also more drag = less acceleration, more power = greater acceleration.
In short, drag reduces the resultant force acting on the car at any given speed, and thus static equilibrium is reached at a lower speed.
For a given level of aero effeciency, drag and downforce are proportional, partly because of viscous drag and partly because of the horizontal component of the pressure on the wings and diffuser. To say that drag and downforce are not the same thing is fundamentally unsound because the horizontal component of the resultant pressure force always exists even if you assume viscosity is zero.
So basically put, downforce and drag are the vertical and horizontal components of the same force.
But not all drag is associated with downforce, of course. Indeed, a fair percentage of a car's drag is just stuff like the wheels/tyres, suspension arms, etc.
I'd almost say more than half of the form drag comes just from the tyres... :?
Yes, most likely. But of the total drag, the tyres are a smaller percentage - downforce associated drag being a fair chunk of a car's total drag at high speed.
dans79
267
Just_a_fan wrote:
24 Sep 2021, 16:14
Zynerji wrote:
24 Sep 2021, 15:41
Just_a_fan wrote:
24 Sep 2021, 09:02
Yep, Scarabs has said many times that the rear wind generates ~30% of a cars total drag.
197 104 103 7
Gillian
Gillian
That makes sense if you take into account the purpose of the rear wing and it being positioned relatively high. Still a lot 30% damn.
dans79 wrote:
24 Sep 2021, 16:20
Just_a_fan wrote:
24 Sep 2021, 16:14
Zynerji wrote:
24 Sep 2021, 15:41
I've seen similar around the place. Here's one from t'web, for example:
El Scorchio
Just_a_fan wrote:
24 Sep 2021, 17:29
dans79 wrote:
24 Sep 2021, 16:20
Just_a_fan wrote:
24 Sep 2021, 16:14
https://cdn.substack.com/image/fetch/w_ ... 20x705.png
Really illustrates how powerful and key the floor and diffuser are. You can see why trimming the floor caused a bunch of the teams so many issues.
Gillian
Gillian
Just_a_fan wrote:
24 Sep 2021, 17:29
dans79 wrote:
24 Sep 2021, 16:20
Just_a_fan wrote:
24 Sep 2021, 16:14
Thank you, very nice illustration.
FW17
168
I would have thought the front wing some times called the front diffuser woul have low drag just like the floor diffuser
FW17 wrote:
24 Sep 2021, 18:23
The front wing does more stuff than the diffuser - the vortices that the teams make use of all make drag, for example.
FW17 wrote:
24 Sep 2021, 18:23
A front wing and front diffuser are two very different things with different jobs. The front diffuser will still work without clean air in front of the car, the front wing will not. Front diffuser normally has an air splitter in front of it, just like the floor/rear diffuser of the car (This is the "Tea tray" part that you see on F1 cars). A front diffuser is sometimes conjoined to the inboard part of an LMP car front wing blurring the lines, but look on a website like "Mulssanne's corner" to see LMP cars analyzed and you will see what the original front diffusers look like. It's sorta stretching it to say F1 cars have front diffusers, the closest thing would be the "Capes" but these are more like vanes for conditioning the air.
☄️ Myth of the five suns. ☄️
LxVxFxHxN
