Alpha Tauri AT03
vorticism
323
Re: Alpha Tauri AT03
08 Sep 2022, 02:45
It may not look like it exactly but I think there is a bargeboard there, it's just not big; the angle makes it look like it's not really extending beyond the floor leading edge, but I think it does a bit. But yes, you're right it's a much smaller bargeboard than most teams run now. Way smaller.
+1 I'd upvote but the code is broken (that or a petty mod) Good overview, I was mistaken by the angle of the photo. By comparison other bargeboards f.e. RB18 don't point inward as much and don't have a bend midway. Single face vs bi-facial.
01 Jul 2022, 01:02
Thank you @roostfactor for the link to the images
𓄀
I don't see anything new compared to France spec
New front wing assembly on the car today
They've finally got rid of their weird nose
etusch
131
I wonder how their car will end up next year? when they get rear end of redbull car.
johnny comelately
johnny comelately
110
So, what of the Gasly pit fire?
are they running an injector at the turbo inlet?
bigblue
Pierre also lost a bit of time with a small fire after connecting the fuel breather, which looked worse than it was, and we were able to quickly get the car back out.
https://scuderia.alphatauri.com/en/2022 ... -practice/
johnny comelately wrote:
30 Sep 2022, 21:18
:lol: How would that be even remotely possible under the current technical regulations?
johnny comelately
johnny comelately
110
01 Oct 2022, 00:23
30 Sep 2022, 21:18
Rather than larf like a clown and make things personal, just give an opinion as to why there was a fire, which is quite the complex question at the top of the airbox.
And to be a rules based thinker prevents lateral thinking, so what is your considered opinion?
For instance is the fuel tank vented into the inlet to make use of those fumes?
01 Oct 2022, 01:19
01 Oct 2022, 00:23
30 Sep 2022, 21:18
I wasn't trying to insult you or make anything personal :wtf:
The fuel breather is located on the left hand side of the car just behind the halo, it's not venting into the inlet.
As scarbs explains:
saviour stivala
saviour stivala
For a much clearer picture of the fuel filter in its location go too. ‘’why red bull has added a shelf to its engine cover’’.
What is actually pressurized is not the fuel tank but the fuel collector pod inside the fuel tank.
johnny comelately
johnny comelately
110
OK, no problem.
Strange happening though, so , one problem with very lean engines is backfire and usually through the inlet. And this often happens at shutdown.
That is why a lot of race engines cut the fuel first, before the ignition.
Maybe that process malfunctioned and maybe from a mapping error..
The above images and comments dont say what the ignition source was...
And you have to deal with the fumes during operation anyway, even road cars vent into the inlet...
And normally on explosive gas systems there are backflash devices...
The inquiry continues.
Zynerji
109
08 Oct 2022, 14:56
https://i.imgur.com/o8k0Qog.jpeg
Interesting. So that hole isn't for "just" driver cooling if it has a heat sink right inside of it!
chrisc90
37
Zynerji wrote:
08 Oct 2022, 22:06
08 Oct 2022, 14:56
Ballast most likely to alter the weight distribution in the car. I imagine it being that far forward gives them a decent bit of scope to play with.
Maybe 24g or 240 on the embossed part in the front of the items in question?
