Mercedes W14 Speculation Thread
De Jokke
Re: Mercedes W14 Speculation Thread
check out this merc news:
reliable?? But 3 tenths from the engine would be a nice welcome
Mercedes AMG + Hamilton => dreamteam!
If you can't beat'em, call Masi!
ajprice
ajprice
21
F1Krof wrote:
13 Feb 2023, 10:00
zeroday wrote:
10 Feb 2023, 22:14
Another day, another livery color tease by Merc.
I do enjoy them though :D
https://i.imgur.com/Jf3SCQ5.jpg
My prediction is that they're going 'Bold High Contrast' color retro design.
I'm going to go with black, and by that I mean 90% of the car will be unpainted bare carbon :D
zeroday
ajprice wrote:
13 Feb 2023, 13:46
F1Krof wrote:
13 Feb 2023, 10:00
zeroday wrote:
10 Feb 2023, 22:14
Ahh yes, black. Always iconic when teams use it, which includes bare carbon! I always wondered why all teams just dont go bare carbon to drop unnecessary weight while leaving on the sponsor stickers. Seems way more efficient. Ok sure Ferrari is "unlucky" to be identified with all red, but tbh if winning is more important, then f--- red, f-- the fans...i wanna win by any (legal) means -- one gram at a time.
zeroday
De Jokke wrote:
13 Feb 2023, 13:45
Many sources have been saying this. No clue the originating source though.
mendis
mendis
19
zeroday wrote:
13 Feb 2023, 13:57
De Jokke wrote:
13 Feb 2023, 13:45
Could be one of us here. :D
Venturiation
Venturiation
98
De Jokke wrote:
13 Feb 2023, 13:45
fake and simply impossible
Andi76
Andi76
404
carisi2k wrote:
13 Feb 2023, 04:06
ringo wrote:
13 Feb 2023, 00:27
As for the 80s design. I am imagine the current zeropod, but a more rectangular and sloped outer edge.
Basically the two concepts I am suggest have that outer flank to push the air wide, similar to what the big pods are doing on the other cars.
As for the midwing, it will not be needed with the above designs. Just visualize it in your mind. That midwing is there because of the downward slope of the current zeropod. Or if you can do a modification to your current zero pod model, see for yourself.
It won't work because the air just tumbles uncontrollably without barge boards. The sidepods could be made small before because the barge boards cleaned up and adjusted the flow. With barge boards banned this control has to be done by the sidepod and this is where the small pod fails. It can't do the controlling of the air like the other sidepods Not only that but I suspect the mid wings actually makes things worse.
Completely agree, and i can't imagine, at least without bargeboards, a solution for managing the front wheel wake anywhere near as well as with the flowfield that larger sidepods create. It will always be a poor compromise in that regard. Also something like the "outer flank" solution. This would certainly improve it a bit, but ultimately even this solution would be inferior to "big" sidepods in this regard, as the effect would reach less far downstream.
Venturiation
Venturiation
98
So there is alot of downsides in the zeopods design but what did mercedes engineers find in it that made them want it?
Remember that this is a team of 100+ engineers working on this and each one has tought of the downsides that we are talking about
but there has to be a reason that they want to keep it
Mercedes said that they explored the other teams design ( ferrari and redbull) and binotto said the same about merc but it was hard to make it work
djones
djones
Venturiation wrote:
13 Feb 2023, 14:31
De Jokke wrote:
13 Feb 2023, 13:45
It's not impossible at all.
It could be the engine was having to run detuned all season because of a reliability issue. In that scenario, if there is a reliability improvement it could open up performance.
Venturiation
Venturiation
98
djones wrote:
13 Feb 2023, 16:27
Venturiation wrote:
13 Feb 2023, 14:31
De Jokke wrote:
13 Feb 2023, 13:45
they did say that couldn't believe how the engine didn't break when they saw how much it got hit by the boucning, but every team runs the engine at best they can, no way you can gain that much unless you do a miracle
zeroday
Venturiation wrote:
13 Feb 2023, 16:32
djones wrote:
13 Feb 2023, 16:27
Venturiation wrote:
13 Feb 2023, 14:31
With so many technical problems all season, to compound their problems by running the engine to its optimal allowable level, would have only exacerbated their problems and made it even harder to narrow down the root causes. Logically, when porpoising and seeing their engine "throwing off bits" due to the banging, it would make more sense to tune down the car until the problems are well understood and fixed. Just common sense really.
Luscion
Luscion
66
zeroday wrote:
13 Feb 2023, 16:51
Venturiation wrote:
13 Feb 2023, 16:32
djones wrote:
13 Feb 2023, 16:27
Lewis did an interview with Heikki Kovalainen and said that they did have to turn down their engines to help with the bouncing, so that could very well be the reason for them finding the extra hp.
chrisc90
38
Easy confirmation of that would be speed trap data or traces in the telemetry. Sure some more of our knowledgeable members would know how to do that
Henri
Henri
-6
Venturiation wrote:
13 Feb 2023, 15:54
Car needs to ride low and have small wings.. in spain the car showed what the simulator is saying..they where the fastest on the straights.. but Lewis said the car is still 1sec slower than it should
Venturiation
Venturiation
98
what could he be talking about? or is it just an ad for the video?
