Diy Honda V10, any takers?
saviour stivala
saviour stivala
Re: Diy Honda V10, any takers?
''what is the end goal what are you dreaming of putting this onto'' Even we old and not so old farts do some dreaming you know.
johnny comelately
johnny comelately
110
Wazari wrote:
01 Dec 2022, 07:50
coaster wrote:
28 Nov 2022, 12:38
I have long pondered an engine design dreamt up out of bits of scrapyard junk.
The old blueprint images released by Honda of their late 80's V6, V10 and V12 all share a similar design dna, namely the 75 degree bank angle.
Isuzu built a 75 degree V6, built under licence from Hondas design bench, the cylinder heads water passages have a nice entry manifold similar to a motorcycles, nice shallow valve angle, nice high port roof, cross bolted main caps.
If you were to obtain 2 early blocks with the short deck, cut a split line in middle of rear 2 cylinders of one block and the front 2 cylinders of the other you have the basis of the V10 block.
Naturally that pair of bores need sleeving after the tig welding unifies both blocks, a turned aluminium bar bolted in the crank tunnel with the caps should keep everything lined up.
The bar should be aluminium as the block needs pre heating before tig welding, steel has a different expansion and would leave 'walk' marks.
I found this out trying to weld a motorcycle crankcase which was holed.
Ok, so block done.
Now the crank, a Volvo crank, shortest stroke obtainable, cut the crank dead centre of main journal on all 5 main journals, this could be done with an edm wire cutter to keep as much parent metal, these 6 segments are set up on a rotary table and the half main journal milled to an ideal stroke and diameter for the new hollow bush to be pressed on.
The hollow bush should be a hardened and ground bush with press fit interference on Volvo crank segments new diameter.
Hardened and ground bushes are easily obtained from bearing manufacturers (skf) as inner races for needle roller bearings.
Now to find some motorcycle conrods to suit this bush outer diameter?
Some motorcycle pistons, Crf450? Drz400?
The camshafts are going to be billet, no easy solutions here.
Bmw throttle bodies, M5?
If i had the keys to a well equipped machine shop. [-o< [-o< [-o< [-o< [-o<
What's the end goal? What are you planning to put this into?
A straight chassis and the worlds longest dyno, Bonneville. The place is full of such dreams :wink:
coaster
16
I was thinking a water ski boat, all forms of motor racing are becoming too muted by over regulation, ski boats are just anything goes.
echedey
echedey
So you think a v12 at 75º would be fine instead of 60º which is how it should be?
622
echedey wrote:
21 Dec 2022, 21:10
F1 V12s ....
Lamborghini did 80 deg
Neotech and Yamaha 70 deg
Ferrari 65 deg
(and with central power takeoff Honda did 90 deg and Porsche did 80 deg)
though the matter in hand was a V10 ?
coaster
16
Echeday, that could be done, but would need a crankshaft like in the Ardeema Braun V12.
The centre main bearing on their one off billet crankshaft is 3 inches long due to its cylinder head design.
Ardeema Braun deserve a thread of their own, i think you would find them of interest.
447
Tommy Cookers wrote:
22 Dec 2022, 16:24
echedey wrote:
21 Dec 2022, 21:10
F1 V12s ....
Ferrari 65 deg
Ferrari also had 75° V12 in the 412T2 of 1995.
And from the 3rd race of the 1994 season in the 412T1.
Ferrari's initial V10 in 1996 was 75°, but then went to 80° in 1998 and 90° in 2000.
