Alpine A523
Re: Alpine A523
New mirrors imaged. Sidepod intakes are also a different shape as per @Blackout
Re: Alpine A523
14 Sep 2023, 11:27
https://i.imgur.com/S43u4Ca.jpeg
The sidepod opening look narrower vertically and wider horizontally. Plus the lower plane of the sidpod opening comes further forward.
KimiRai
KimiRai
205
Re: Alpine A523
The letterbox inlets were there from the start in the launch spec A522 last year, so it's come full circle after the development.
Re: Alpine A523
But the the top lip is swept backwards & the bottom one forwards, following the trend set by RB last year and copied by MCL, AM etc.
This team is mainly following trends in aero since 9 or 10 seasons, except 2 or 3 new fancy designs. Before that they pioneered much more trends than now.
Getty
Motorsport
Re: Alpine A523
Looks like the slide geometry has changed as well? Could easily be the light, but the outer edge seems more ridged... bit similar to the change AMR made in Canada
Re: Alpine A523
Blackout wrote:
14 Sep 2023, 15:10
Getty
Motorsport
https://i.imgur.com/4jIJcF7.jpg
Remember early 2022?
Re: Alpine A523
diffuser wrote:
14 Sep 2023, 16:44
Blackout wrote:
14 Sep 2023, 15:10
Getty
Motorsport
https://pbs.twimg.com/media/FMRYPHqWUAE ... ame=medium
This is similar to the current Mercedes inlet.
Farnborough
Farnborough
89
Re: Alpine A523
In the AF credited picture you can see JUST and almost behind the top of brake caliper sightline that the lower lip of entry has now been brought forward along the tub to make the lower extend further than the top plane.
Very different, in my view to MB, that with overarching remnants of midwing for top entry surface.
Re: Alpine A523
vorticism
323
Re: Alpine A523
14 Sep 2023, 21:58
https://twitter. com/AlbertFabrega/status/1702362743230361721?t=kCb4RVYhU-6RD6GpAbcqkg&s=19
+1 First instance of underside waterslides?
Narrator: "It wasn't."
Looks like they've just squared it off similar to the Ferrari sidepods in this area.
𓄀
Re: Alpine A523
https://it.motorsport.com/f1/news/f1-al ... /10519926/
The Enstone team in Singapore introduces a metal kit on the front wing to strengthen the front wing. Is this an intervention to complete the assembly of the profiles or the adaptation to the Technical Directive TD018?
Re: Alpine A523
Farnborough wrote:
14 Sep 2023, 17:33
ah sorry, the current Alpine and the current Merc are completely different. I was referrging to the launch spec A522 (last year) and the current Merc which both have the overbite inlet.
ThijsMuis
ThijsMuis
Re: Alpine A523
Re: Alpine A523
Taller mousehole, rear brake duct winglet cascade, more aggressive louvres in preparation for Mexico
Re: Alpine A523
Mousehole comparison - photos pulled from Fabrega
New mousehole more rounded and larger radius at the leading side of the mousehole. Taller as well - extends much further up the diffuser sidewall.
