Offset cylinder explained.
650
Re: Offset cylinder explained.
you would need to move the crankshaft axis sideways not up
moving up will help one bank but hinder the other
moving sideways will help both banks
saviour stivala
saviour stivala
Tommy Cookers wrote:
12 Apr 2023, 18:06
Correct, fully agree, to help both banks in a positive way either the cylinder block or the crankshaft have to be moved sideways. facing the front of the engine, with the crankshaft clockwise rotating, the crankshaft is moved to the right, or the cylinder block to the left. But it is claimed that upping the crankshaft has been done in racing engines to lower center of gravity.
474
Not sure if it was in the discussion, but offset cylinders will not be allowed in F1 from 2026.
2026 Regulations
5.6.4 Each cylinder centreline must pass through the crank axis +/-0.1mm.
I don't know if this has been added because someone is doing it, or preemptively outlawing the concept.
Greg Locock
Greg Locock
238
cg height is my guess, positive on one bank negative on the other. Far more important than the piffling changes in combustion and dynamics.
Hoffman900
Hoffman900
220
Greg Locock wrote:
27 May 2023, 00:48
Most likely this.
