Just_a_fan wrote: ↑30 May 2023, 22:53
AMG.Tzan wrote: ↑30 May 2023, 21:32
It’s funny how they changed the track 15-20 years ago tightening T10 and creating a chicane before the last corner just to end back to the original layout with the wider T10 and without the chicane…
I always loved the original layout specially when Motogp races there! The cars will be around 7-8 seconds faster according to twitter
I guess back then the answer to improving safety was changes to the track to make it slower. Today, the cars are inherently safer - Halo
et al, of course - that they probably feel they lose nothing from safety but get to make the show better. The cars will be fast in the last two corners so they should look great. The question is whether the removal of the last chicane will make the racing worse - Barcelona has never normally been a thriller of race so there isn't much scope on that front.
I thought the changes were made to improve racing back then…these last two corners had so much run off still back early 2000s that didn’t provide much of a risk for f1! Yet it was more of a safety issue with MotoGP and Luis Salom’s death there!
I get the feeling the last two corners will make it easier to pass on the straight as you’ll be able use a bit of slipstream before entering the main straight!
The last section was so tight and so traction dependent that the only way to gain through there was by having much better tires! Now that’ll change and drivers will be able to keep up through the last two corners before entering the main straights!
I expect the DRS zone to be shortened too…
